96blktahoe Posted February 17, 2010 Report Posted February 17, 2010 okay heres the deal i just got my new headunit and its an xovision x348NT and i have 4 kickers hooked up to a memphis 1.500 class d mono block well heres the problem everytime a song comes on it will hit a split second and throws it in protect mode idk how to fix it because there are so many rca outputs and inputs to use i will list them. subwoofer (brown) i was thinking this was it but theres only one rca for it so i havent tried it Front left rca out (white) Front right rca out (red) Rear left rca out (purple) Rear right rca out(blue) Aux right in(red) aux left in (white) Video in(yellow) Backupcamera video out (yellow) video out (yellow) What one does it hook up to and why is it going into protect mode? Quote
uhoh_45 Posted February 17, 2010 Report Posted February 17, 2010 you need a Y splitter and use that one brown sub out Quote R.I.P! (Nov-29-2009) 92 explorer - 4 Atomic Apxx 15s duel .7s - 4rth order bandpass wall -4 powerbass XA-3000D's - 16 8volt batts wired to 16 volts - (9+/9-) runs 0gauge - 152.3 Db @ 29hz BUILD LOG current build 97 chevy lumina4 - 1 Atomic Apx 18 - 6 cube slot port trunk sealed off - 1 powerbass XA-3000D - 2 optima G31s in spare tire18 1 run 1/0 lumina build log
96blktahoe Posted February 17, 2010 Author Report Posted February 17, 2010 you need a Y splitter and use that one brown sub out i tried that im throwin that picea junk out and goin back to my kenwood kdc 991 Quote
96blktahoe Posted February 17, 2010 Author Report Posted February 17, 2010 its not the head unit. i think its the amp because it turns on just fine but when sound goes through it it puts it on protect mode Quote
huh?do-what? Posted February 17, 2010 Report Posted February 17, 2010 what ohm are the speakers? are they dual voice coil? Take your speakers out and doublecheck the wiring. Make sure no wires are touching or reversed. Are the speakers brand new? If not, get a multimeter and ohm them out to make sure they are ok. Or get a 9 volt battery and touch each positive and negative to the 2 terminals on the battery. Positive to large terminal, negative to small. That's all I know to tell you for now. Good luck. Quote God damn its hot today. My balls are stuck to my leg.
cqtama Posted February 17, 2010 Report Posted February 17, 2010 which kickers? how are they wired? Quote R.I.P '01 blazer you treated my ears well until your transmission blew up. New Project [top secret] 149.0 db on music driver window open; so close I feel some boners are fueled by viagra and not true intimacy!......if you know what i mean.... I swear... sometimes I wish I was retarded so I could just agree with everyone x.
96blktahoe Posted February 17, 2010 Author Report Posted February 17, 2010 (edited) they are 4 ohm kicker comps the black and yellow ones i got some new rca cables and it worked for about 15 seconds and then went back into protect mode. like if i turn the bass down it will work but when i turn the dbs up past -3 it goes itno protect mode they are hooked up to a memphis 1.500 class d mono the speakers are all 4 rated at 600 rms total the amp is 500. the amp turns on just fine but when sound goes thorugh it, it will go red. should it be on input side of the amp or ouput side? i was told that they will be tookin down to 1 ohm is that safe for amp and subs? and yes they are single voice coils Edited February 17, 2010 by 96blktahoe Quote
sven6977 Posted February 17, 2010 Report Posted February 17, 2010 they are 4 ohm kicker comps the black and yellow ones i got some new rca cables and it worked for about 15 seconds and then went back into protect mode. like if i turn the bass down it will work but when i turn the dbs up past -3 it goes itno protect mode they are hooked up to a memphis 1.500 class d mono the speakers are all 4 rated at 600 rms total the amp is 500. the amp turns on just fine but when sound goes thorugh it, it will go red. should it be on input side of the amp or ouput side? i was told that they will be tookin down to 1 ohm is that safe for amp and subs? and yes they are single voice coils according to the specs i just looked up the amp should be fine down to 1ohm. double check the wiring of the subs to make sure its correct. There are plenty of wiring guides around to show you what it should look like. basically you should have two pairs wired in parallel and then those wired in parallel together. (4/2)/2=1 Quote Rowan University Electrical Engineering LINK TO MY BUILDDDDD Current Setup in my 00' Hyundai Accent: Pioneer DEH-P6900UB RE.6.5C AUDIO 500w 6.5" COMPONENT CAR SPEAKERS Eclipse SE 6500 (6.5 coax in rear deck) two Kicker C124's in a t-line tuned to 28.6Hz Kenwood KAC-7204 US amps 1600.4 V2 Upcoming Build this summer: T-Line enclosure for two C124's tuned to 28ish hz O_O amp my speakers with a US amps 1600.4. Second Skin Should be fun
96blktahoe Posted February 17, 2010 Author Report Posted February 17, 2010 according to the specs i just looked up the amp should be fine down to 1ohm. double check the wiring of the subs to make sure its correct. There are plenty of wiring guides around to show you what it should look like. basically you should have two pairs wired in parallel and then those wired in parallel together. (4/2)/2=1 what do you mean wiring? parrelle Quote
96blktahoe Posted February 17, 2010 Author Report Posted February 17, 2010 how i have it hooked up is i have 8 wires inside the box 4 for red and 4 for black they are hooked to the subs which have a femal connecter crimmped to them which all 8 are hooked to male connectors on the speakers terminals. i then took wire ffrom the termianals ran them twisted all postives togather hooked them into the postive block of the amp and twisted all negatives and put them into the negative side of the block is this wrong? Quote
