RCAS THROWS IT INTO PRTC MODE HELP!
If I'm understanding you right, then yeah. that should be 1ohm.... My guess is either a problem with the rca outs on the headunit end or the input on the amp. was the amp/headunit brand new?
Rowan University Electrical Engineering
LINK TO MY BUILDDDDD
Current Setup in my 00' Hyundai Accent:
Pioneer DEH-P6900UB
RE.6.5C AUDIO 500w 6.5" COMPONENT CAR SPEAKERS
Eclipse SE 6500 (6.5 coax in rear deck)
two Kicker C124's in a t-line tuned to 28.6Hz
Kenwood KAC-7204
US amps 1600.4 V2
Upcoming Build this summer:
T-Line enclosure for two C124's tuned to 28ish hz O_O
amp my speakers with a US amps 1600.4.
Second Skin Should be fun ^_^
sounds like you may have a bad sub
www.bassproducers.com
TEAMS
TEAM BASSPRODUCERS, TEAM HERTZ (VA)
*Ranger System*
(4) 18" Kicker Comp
(4) 10" Kicker Comp
Dual Stinger Alts.
(5) Rockford Punch 200's
(2) Punch 100's
*Outlander System*152.6 DB so Far*
(8) TXX-APX12W
(2) AP-30001D'S
(2) AP-2004'S
(8) APMB6'S
(4) KHC2400'S
honestly, one of the subs has to be bad or one of your connections are bad. If the amp/hu/old subs worked. but now with amp/new&old hu/new subs dont work its gotta be the new subs. possibly a mismatched coil in your order. (if one of them is a 2ohm sub your gonna get below 1ohm and amp=unstable)
Pioneer DEH-P6900UB
Kenwood KAC-7204
US amps 1600.4 V2
try turning your gain down on your amp the new headunit could have higher output voltage and could be sending the amp into protect cause clipping
R.I.P!
(Nov-29-2009)
92 explorer
current build
  • Who's Online   0 Members, 0 Anonymous, 1314 Guests (See full list)
