ok got a problem.... infact a VERY big PROBLEM.
Finally got my cashflow back in shape and i went and brought 4 SUBS (12inch) Pioneer.... And thought it'd be louder than my 15" Vibe spaces (x2)
However, i have 2 amps. 1200rms each.....
Subs= Pioneer TS-W3004SPL - 1000watt RMS 3000peak. each
Amps= JBL 1201.1 - 1200rms at 2 Ohm.
Now my problem is that the Subs are 4Ohm Dual Voice Coil. CLICK HERE FOR SUB SPEC PAGE
CLICK FOR MORE INFO ON AMP
I cant seem to figure out how to wire them, i used the RF site and got this
OR THIS
IF I do it in to 4ohms, im only going to get 750 RMS...
So how can i connect all 4 subs to the 2 amps to get maximum output?
Thanks in advanced, i hope i've been able to give as much info as possible
Connect 2 subs at 1 ohm to each amp...Just like your picture says...That is what I would do..Someone might do different!! Is your amp 1 ohm stable?? MY Badd you want 2 ohms right..I need to read better...Umm..I don't think your amp is stable at 1 ohm...So 2 ohms...
you cant get max power with the coil config you have, Im pretty sure you amp isnt 1 ohm stable, and I wouldnt try it unless you have a warrenty.
nope its not..... thts the diagrams i get,,,,, they are right however i need to wire diffrently.... Anyone know any diffrent way??
I mean i dont mind even if the subs were getting 500watts each but im just curious to know if there is a bend apart from either gettting 2 new 1Ohm Stable amps or just wiring at 4ohms.....i mean if i cant find a soloution i'll have to wire them in sereies at 4 ohms no choice, but if there is..... thennn....
Any Alternatives?
Thanks for the replys btw! :D
Wire each sub to 2ohms & then it's own amp. As long as the gains are properly set, they will knock for sure.
1- T1000.1bd's
3 Maxx 29 deep cycles
4 runs of 1/0 gauge
-Big 3
All in a CAR.
i've already done tht, when i wire the 2subs to the one amp, even before i can get descent knock it cuts....
best was when i wired 1 sub to the amp at 2ohms, it knocks alright! but i guess after looking around for some time now im going to have to wire them at 4 ohms in series... :(
Thanks for the input!
idea....sell your amps and buy 2 T20001bds and wire to 1 ohm each or 1 t40001bd and wire it to 2 ohm. other than that your either gonna push your current amps too hard or not at full potential.
NoFearX18 said:
trainman0978 said:
^^^^agreed^^^
Eclipse cd7000
ok today i done everything, but i had to re-wire amps 3 TIMES and almost fired both my amps and voice coils.! lol i just aint used to the idea of series wiring, but however i got it right today and DHAM even at 350watts RMS each Sub they BANG hard! i wired them in to 4ohm stable.
Although in my old Nissan 2003 Make, i could see flex, but not in this car, new car is a seat ibiza.... hopefully soon i'll post pictures of system in members builds :D
