Blackedout Posted February 18, 2010 Report Share Posted February 18, 2010 Wire them up to 1 and check the box rise. Your kicker amp will handle it if there isn't fluctuation in the voltage. If your voltage is dippin and your electrical can't support it, your amp will go into protect. If you have good electrical, it will probably be fine. Trunk Build Log Link to comment Share on other sites More sharing options...
CJ18 Posted February 20, 2010 Report Share Posted February 20, 2010 Some of Kickers older amps were 1 ohm stable. I wired my 2500.1 to 1 ohm and it clipped. Link to comment Share on other sites More sharing options...
chevyhoe08 Posted February 20, 2010 Report Share Posted February 20, 2010 I played my zx300.1 at .5 ohm for about a year and now my buddy has it running it at .5 ohm and it's been about another year, and still working perfectly. It would only go into protect if I would play for an hour+ at full tilt during the summer, other than that it never went into protect. Electrical was completely stock too, even without big 3 done. So I know if you have a good electrical, the zx amps can handle .5 ohm load, so that means it will obviously hold a 1 ohm load. you can't compare the load of power of a 300 watt amp to a 2500 2-18" Fi Btls 2-RF T2500-1bd box 14cu.ft after displacement tuned @ 32hz. Socal Box Designer/builder Link to comment Share on other sites More sharing options...
