cvxsmitty58 Posted February 18, 2010 Report Posted February 18, 2010 So i bought a aq2200d and now i want to know if you guys think this is enough electrical to support it. First i have the Big 3 done in 0ga. Next i have a run of 0/1 running to the positive on on the back battery. Right now i have a run of 4ga for the negative run. I have an everstart battery in the front which is rated at 1000CA or 700CCA. I am wondering if another one of these in the back will be enough for the amp or not. The back battery will be grounded with 0ga. I know its probably not the best battery to run but for 75-80 bucks i think it will be good for a while. All the power wires will be 250amp fused...........Any suggestions or input is greatly appreciated. Btw, I'm 3 hours away at college right now so I'm pretty much buying stuff off the internet and next weekend i'll install it all.
t-money Posted February 18, 2010 Report Posted February 18, 2010 no. u need a H/O alt. i have the same amp with close to same electrical. U NEED A H/O ALT haha. mine is being made now. 2002 ford focus hatch pioneer DEH-P8400bh infinity kappa 6.5 components front and rear XS Power D1200 Shuriken BT-100 audioque 120.4 2 15 inch audioque HDC3 D2 2 audioque 2200d big 3 mechman 220a alt with external regulator 479-418-3056
OrionStang Posted February 18, 2010 Report Posted February 18, 2010 So i bought a aq2200d and now i want to know if you guys think this is enough electrical to support it. First i have the Big 3 done in 0ga. Next i have a run of 0/1 running to the positive on on the back battery. Right now i have a run of 4ga for the negative run. I have an everstart battery in the front which is rated at 1000CA or 700CCA. I am wondering if another one of these in the back will be enough for the amp or not. The back battery will be grounded with 0ga. I know its probably not the best battery to run but for 75-80 bucks i think it will be good for a while. All the power wires will be 250amp fused...........Any suggestions or input is greatly appreciated.Btw, I'm 3 hours away at college right now so I'm pretty much buying stuff off the internet and next weekend i'll install it all. Only bad thing I see is your ground wire should be the same size as the power wire. Yes and alternator^^^^ SMD Super Seller My Feedback Thread
cvxsmitty58 Posted February 18, 2010 Author Report Posted February 18, 2010 As far as the batterys, does it make a huge difference that there not super expeinsive car audio batterys........i mean my plan is to get some eventually. I think my alternator is rated around 130 amps btw
cubs_fan0718 Posted February 18, 2010 Report Posted February 18, 2010 i wouldnt get a regular car battey it can omit toxic fumes. get a deep cycle or something along those lines. something that says u could mount it in any position, ie. upside down, on its side etc. also a deep cycle will work better than a regular battery. 06 Impala SSKenwood Excelon DDX593 Ampere Audio 150.4 Ampere Audio 5K1 XS D4700 (front)Mechman 320a Alt. w/ Big 3 Lots of Second Skin Damplifier Under Construction for 2017
skittlesRgood Posted February 18, 2010 Report Posted February 18, 2010 As far as the batterys, does it make a huge difference that there not super expeinsive car audio batterys........i mean my plan is to get some eventually. I think my alternator is rated around 130 amps btw and your trying to add 200 amps to it. do the math lol. there is a reason audio batteries are not 80 bucks. the everstart battery wont discharge as fast so the power may be there but itll still be starving the amp. maybe 3 of those batteries in the back will do it without a HO alt, thats 4 total, but just 1 or 2 of those things wont cut it. are those batteries vented to sealed? if they are vented then its basicaly venting poison into the car. If I answered you in a well mannered, informative way, you asked a good question or had a good attitude. If I was an asshole, you asked a stupid question or you had a fucktard attitude... or I was in a bad mood. Team BassickHU: Pioneer AVIC Z110Front: Peerless SLS 6.5", Peerless HDS 4", Rainbow tweeter - running activeAmp: JL HD600/4 and DC 4 channel (bridged to midbass)Processor: JBL MS-8Subs: 2x 12" AA MayhemsAmp: DC 3kElectrical: DC power 270xp alt. 1/0 big 4. XSpower D3400 and six D680s. http://www.stevemeadedesigns.com/board/topic/121795-29-update-the-buick-is-getting-a-rebuild/ Top career scores: DBdrag 151.7 MECA SQ 82.25My SOTM build Yeah. im pretty sure they dont warranty retarded people.
cvxsmitty58 Posted February 18, 2010 Author Report Posted February 18, 2010 Yeah i kinda figured it wouldnt be enough, i knew it wasnt the right thing but i guess beng cheap is never good. My next choice was a kinetik 2000. If i run this battery will i need to worry about using a battery isolator? Srry for all the questions.
skittlesRgood Posted February 19, 2010 Report Posted February 19, 2010 no isolator. i dont think one kinetik will be enough with out a bigger alt. If I answered you in a well mannered, informative way, you asked a good question or had a good attitude. If I was an asshole, you asked a stupid question or you had a fucktard attitude... or I was in a bad mood. Team BassickHU: Pioneer AVIC Z110Front: Peerless SLS 6.5", Peerless HDS 4", Rainbow tweeter - running activeAmp: JL HD600/4 and DC 4 channel (bridged to midbass)Processor: JBL MS-8Subs: 2x 12" AA MayhemsAmp: DC 3kElectrical: DC power 270xp alt. 1/0 big 4. XSpower D3400 and six D680s. http://www.stevemeadedesigns.com/board/topic/121795-29-update-the-buick-is-getting-a-rebuild/ Top career scores: DBdrag 151.7 MECA SQ 82.25My SOTM build Yeah. im pretty sure they dont warranty retarded people.
Boon Posted February 20, 2010 Report Posted February 20, 2010 Jesus guys it's 1 2200w amp. He doesn't need 4 batteries or an H/O alt. 1 big battery would be fine. Or maybe the stock battery and one decent battery in the back. 10.x volts fo' life!
