Ebes Posted February 18, 2010 Report Share Posted February 18, 2010 I wanted to amp more door speakers along with my 6x9s in the back. I took out my headunit only to find that there is only 1 set of rca jacks which i am using for my amp in the back for my subs. Is there away to amp my interior speakers without using the rca cable from the head unit? Thanks, Matt Quote Link to comment Share on other sites More sharing options...
wL<3bass Posted February 18, 2010 Report Share Posted February 18, 2010 (edited) You could a) get a new headunit Run the single set of RCAs (provided they aren't used for only sub output) into a 2 or 4channel amp and then run a set of RCAs from your pass-thru on your 2/4channel amp into your sub amp. c) Do high voltage converters....but they suck imo. Edited February 18, 2010 by wL<3bass Quote Vehicle: 1997 S10 Blazer 4dr 4X4 Exterior: Rear End Bagged, Black Grill, Lifted 2" Amplifiers: Rockford Fosgate T8004 & T10001bd Batteries: 2 Stinger SPV35, Kinetik HC2400 Electrical: Big 3, DC Power 290amp Alternator w/ MLA at 15.5v Enclosure: 4.2 ft³ @ 33Hz 84sq.in. of port (20sq.in. per cube) Headunit: Eclipse CD3200 w/ 80G iPod Mids/Highs: Rockford T152s (a-pillars), Rockford T162s (doors) Subwoofers: 1 15" Fi BL Fully Loaded Wire: All 1/0g Kicker Hyperflex My YouTube Videos My Fiberglass A-Pillar Build My "Seamless" Looking Box Build My DD1508 T-Line Bandpass Build "Seamless" w/ Acrylic Windows (for '05 TrailBlazer) My Stealth 8" Fiberglass Build (for '05 TrailBlazer) My Build For A Friend's '08 Cobalt 15" BL Sealed Off From The Trunk My feedback/references... Link to comment Share on other sites More sharing options...
Blackedout Posted February 18, 2010 Report Share Posted February 18, 2010 I'd recommend getting a different deck.... But you can look into a LOC (Line output converter) just to make your deck work for you. Quote Trunk Build Log Link to comment Share on other sites More sharing options...
AssKicker Posted February 18, 2010 Report Share Posted February 18, 2010 Yep an LOC would be the best, I suggest a Scosche I have heard no complaints about it and it's fairly cheap ($15 or so on eBay) Quote Link to comment Share on other sites More sharing options...
basshead4life Posted February 18, 2010 Report Share Posted February 18, 2010 Yep an LOC would be the best, I suggest a Scosche I have heard no complaints about it and it's fairly cheap ($15 or so on eBay) walmart brands FTW! lol Quote Team S.M.D. Maritime Car Audio- (2) 18" SSA ZCON D1 - American Bass 500.1 - 60 ft of 3/0 -480 Ah of battery - (2) stock alternators (70 +90) - Kenwood Excelon x-794, 4v preouts car audio is just a LOT more complicated than "this amp does this power" or "this sub will be this loud". its like 2 + 2 = banana. (if that confuses you then you get the point) lol Link to comment Share on other sites More sharing options...
kmalinich Posted February 18, 2010 Report Share Posted February 18, 2010 I'd say that the RCA on your deck isn't just for subwoofer output.. but I may be wrong. And if you amp doesn't have a pass thru, you can use an RCA splitter, but you need to re-set your gains when you use an RCA splitter because it will drop your input voltage. Quote Link to comment Share on other sites More sharing options...
Nirvalica Posted February 18, 2010 Report Share Posted February 18, 2010 (edited) Why not get a crossover? Like a 3-way. This would work. It can take two channel input (pair of RCA's) and have a 3-way output. So you can set the high pass for the front and rear, and the low pass for the sub. EDIT: I'll also boost the voltage of the RCA signals to the amps, so that's another plus. Edited February 18, 2010 by Nirvalica Quote My Youtube Page. Check it out The "SAV" - Sub-aural Assault Vehicle Kenwood eXcelon KDC-X993 Image Dynamics CTX 6.5" Components Q-logic 6.5" kick pods CDT 6.5" CL-E6NEO Front door Midbass Kicker ZX350.4 Knukonceptz SS Karma 4 channel 6m RCA Fi Q 18" w/ brushed aluminum dust cap 7cu ft. ported box tuned to 28hz Sundown SAZ-1000D Iraggi 240 amp Amputator Alt Big 3 in Monster 1/0awg Second Skin Damplifier Lite on roof and front doors Link to comment Share on other sites More sharing options...
kylecm85 Posted February 18, 2010 Report Share Posted February 18, 2010 just remeber don't split that signal to much because you will make it even weaker than it prob is. So i would just look into getting a new h/u Quote 94 lincoln mark viii h/u: kenwood kvt 614 Excelon comps: alpine type x amps: mtx 1501d mtx 4004 sub:2 DC lv4 12 wiring jl audio 0awg 8 awg sub jl audio 4 awg for mid and highs amp myspace.com/kylecm85 carstereolexington.com Link to comment Share on other sites More sharing options...
Ebes Posted February 19, 2010 Author Report Share Posted February 19, 2010 just remeber don't split that signal to much because you will make it even weaker than it prob is. So i would just look into getting a new h/u Yeah i thought about it and a new headunit would be the easiest solution IMO. Thanks for all the responses Quote Link to comment Share on other sites More sharing options...
tyhead Posted February 19, 2010 Report Share Posted February 19, 2010 Yep an LOC would be the best, I suggest a Scosche I have heard no complaints about it and it's fairly cheap ($15 or so on eBay) I have heard nothing but shit about Scosche, but I could be wrong Quote Link to comment Share on other sites More sharing options...
