I wanted to amp more door speakers along with my 6x9s in the back. I took out my headunit only to find that there is only 1 set of rca jacks which i am using for my amp in the back for my subs. Is there away to amp my interior speakers without using the rca cable from the head unit?
Thanks, Matt
You could
a) get a new headunit
B) Run the single set of RCAs (provided they aren't used for only sub output) into a 2 or 4channel amp and then run a set of RCAs from your pass-thru on your 2/4channel amp into your sub amp.
c) Do high voltage converters....but they suck imo.
Edited by wL<3bass
Vehicle: 1997 S10 Blazer 4dr 4X4
Exterior: Rear End Bagged, Black Grill, Lifted 2"
Amplifiers: Rockford Fosgate T8004 & T10001bd
Batteries: 2 Stinger SPV35, Kinetik HC2400
Electrical: Big 3, DC Power 290amp Alternator w/ MLA at 15.5v
Enclosure: 4.2 ft³ @ 33Hz 84sq.in. of port (20sq.in. per cube)
Headunit: Eclipse CD3200 w/ 80G iPod
Mids/Highs: Rockford T152s (a-pillars), Rockford T162s (doors)
Subwoofers: 1 15" Fi BL Fully Loaded
Wire: All 1/0g Kicker Hyperflex
My YouTube Videos
My Fiberglass A-Pillar Build
My "Seamless" Looking Box Build
My DD1508 T-Line Bandpass Build "Seamless" w/ Acrylic Windows (for '05 TrailBlazer)
My Stealth 8" Fiberglass Build (for '05 TrailBlazer)
My Build For A Friend's '08 Cobalt 15" BL Sealed Off From The Trunk
My feedback/references...
Yep an LOC would be the best, I suggest a Scosche I have heard no complaints about it and it's fairly cheap ($15 or so on eBay)
walmart brands FTW! lol
Team S.M.D.
Maritime Car Audio- (2) 18" SSA ZCON D1
- American Bass 500.1
- 60 ft of 3/0
-480 Ah of battery
- (2) stock alternators (70 +90)
- Kenwood Excelon x-794, 4v preouts
car audio is just a LOT more complicated than "this amp does this power" or "this sub will be this loud". its like 2 + 2 = banana. (if that confuses you then you get the point) lol
I'd say that the RCA on your deck isn't just for subwoofer output.. but I may be wrong. And if you amp doesn't have a pass thru, you can use an RCA splitter, but you need to re-set your gains when you use an RCA splitter because it will drop your input voltage.
Why not get a crossover? Like a 3-way. This would work. It can take two channel input (pair of RCA's) and have a 3-way output. So you can set the high pass for the front and rear, and the low pass for the sub.
EDIT: I'll also boost the voltage of the RCA signals to the amps, so that's another plus.
Edited by Nirvalica
My Youtube Page. Check it out
The "SAV" - Sub-aural Assault Vehicle
Kenwood eXcelon KDC-X993
Image Dynamics CTX 6.5" Components
Q-logic 6.5" kick pods
CDT 6.5" CL-E6NEO Front door Midbass
Kicker ZX350.4
Knukonceptz SS Karma 4 channel 6m RCA
Fi Q 18" w/ brushed aluminum dust cap
7cu ft. ported box tuned to 28hz
Sundown SAZ-1000D
Iraggi 240 amp Amputator Alt
Big 3 in Monster 1/0awg
Second Skin Damplifier Lite on roof and front doors
just remeber don't split that signal to much because you will make it even weaker than it prob is. So i would just look into getting a new h/u
94 lincoln mark viii
h/u: kenwood kvt 614 Excelon
comps: alpine type x
amps: mtx 1501d mtx 4004
sub:2 DC lv4 12
wiring jl audio 0awg 8 awg sub
jl audio 4 awg for mid and highs amp
myspace.com/kylecm85
carstereolexington.com
