Um I'm thinking this is spam because it looks like he photoshopped some really crappy speakers into the picture to make them look big considering they arn't sitting in anything
your retarded-
as for OP are you using one or 2 subs if only using one sub its going to be hard to find a powerful amp that puts out the power at 4 ohms now if your using both subs you can wire them down to 2 ohms which you'd be good going with a solid 3k amp at 2ohms and with your budget an audiopipe 3k would be your best bet
R.I.P!
(Nov-29-2009)
92 explorer
current build
^I guess you missed where he says
What kind of amp should I use for one
2015 Mazda 6
JVF Customz 4.0 Proto 15>Wolfram W4500 @ .5ohm
2 Sundown Neo 6.5 + 2 CT Meso Tweeters (Front) x Kicker KS6.5 (Rear)>JL Audio VX400/4i
NSB-AMG35 (front) / 40ah Lithium Headway (Rear) built by Erni Audio & Electrical
your retarded-
The Box is going to be way too big. I can only fit one in the bed of my Truck.
Whats better the audiopipe 3k?? Or a Hifonics Colossus??
For one sub?
Current set up
Subs: (4) B&C 6's
Amp: (1) Clarion 4 Channel 640watt
Headunit: JVC KD-R800
Electrical:Stock
Box: Custom built out of 1'' Russian Birch
Wire: 4 gauge wire
Next Set Up (Adding to what I have)
Subs: (2) Celestion Vintage 30, (1) 21'' B&C
Amp: So far Legacy Predator 4000 watt. (Looking for a colossus)
Wire: 1 Gauge
Electrical: (4) Gel Batteries, alt out of a Ambulance
Box: Designed not built yet
Welcome to Idiotville, population: you.
OP, you're better off running a dual monoblock as mentioned or a pair of smaller amps like the Sundown SAZ-1500D - this way the amps will see 2 ohms each and make more power. Running a big-ass amp at 4 ohms is kinda stupid.
Stetsom might be a good option here... especially if you got one or 2 of the '2 ohm' option amps
10.x volts fo' life!
Thank you Everyone for your help.
Current set up
Subs: (4) B&C 6's
Electrical:Stock
Wire: 4 gauge wire
Wire: 1 Gauge
  • Who's Online   1 Member, 1 Anonymous (See full list)
