kx519 Posted February 21, 2010 Report Posted February 21, 2010 Can i use a resistor to lose some impedance in my wiring? I have a huge box of high grade resistors that i have no use for and if i can throw one in parallel with my speakers to get a lower impedance that would be amazing! 84 K5 Blazer 3" body, 2" Suspension 35" Maxxis Bighorn 100amp Alt Marine deep cycle for the amps (freebie) KnuKonceptz 1/0 8 Hifonics HFi 12D4's in ~19cubes tuned to 35hz Audiopipe AP-18001D RF 5x8's in the kicks Almani 5.25 comp. in back Kenwood KAC-645 --IN THE FUTURE-- None. <!--quoteo(post=0:date=Feb 3 2010, 09:12 AM:name=Decaf)--><div class='quotetop'>QUOTE (Decaf @ Feb 3 2010, 09:12 AM)</div><div class='quotemain'><!--quotec-->we seriously need some butt plugs so you guys stop spewing chit talk<!--QuoteEnd--></div><!--QuoteEEnd-->
CaptainzPlanetz Posted February 21, 2010 Report Posted February 21, 2010 Can i use a resistor to lose some impedance in my wiring?I have a huge box of high grade resistors that i have no use for and if i can throw one in parallel with my speakers to get a lower impedance that would be amazing! It would most likely blow the resistor, but if you did have one that would take the power, yes it would lower your impedance, the only problem is your sub wont see the additional power you would think you should get, since the resistor is absorbing half of the total power the amp is putting out. ¿ǝɯɐƃ ǝɥʇ Trolls never learn............ All BS aside, If I see one more comment in here that is NOT about the pre-sale, I will start the vacations. And that includes the trolls feeding the trolls. YOU THE ONE THAT SOUND LIKE A OGER AND HUMPBACK/TROLLS? Add "SMDLIFER" on Xbox LIVE to play with other SMD members.
Ben Building Posted February 21, 2010 Report Posted February 21, 2010 Those are some baddd azz resistors, homie! LOL Don't do that. Just build a proper box for your subs to keep impedance rise down. $22 and a sunny Sunday!
bkolfo4 Posted February 21, 2010 Report Posted February 21, 2010 It would most likely blow the resistor, but if you did have one that would take the power, yes it would lower your impedance, the only problem is your sub wont see the additional power you would think you should get, since the resistor is absorbing half of the total power the amp is putting out. x2 It will lower the impedance, but it does absolutely nothing for you! Current system: 1997 Blazer - (4) Customer Fi NEO subs with (8) American Bass Elite 2800.1s Previous systems: 2000 Suburban - (4) BTL 15's and (4) IA 40.1's = 157.7 dB at 37 Hz. 1992 Astro Van - (6) BTL 15's and (6) IA 40.1's = 159.7 dB at 43 Hz.
kx519 Posted February 22, 2010 Author Report Posted February 22, 2010 Those are some baddd azz resistors, homie! LOLDon't do that. Just build a proper box for your subs to keep impedance rise down. $22 and a sunny Sunday! i get less than an ohm of rise. But i can only wire my subs to 1 or 4 ohms, and i wanted a 2ohm load. 84 K5 Blazer 3" body, 2" Suspension 35" Maxxis Bighorn 100amp Alt Marine deep cycle for the amps (freebie) KnuKonceptz 1/0 8 Hifonics HFi 12D4's in ~19cubes tuned to 35hz Audiopipe AP-18001D RF 5x8's in the kicks Almani 5.25 comp. in back Kenwood KAC-645 --IN THE FUTURE-- None. <!--quoteo(post=0:date=Feb 3 2010, 09:12 AM:name=Decaf)--><div class='quotetop'>QUOTE (Decaf @ Feb 3 2010, 09:12 AM)</div><div class='quotemain'><!--quotec-->we seriously need some butt plugs so you guys stop spewing chit talk<!--QuoteEnd--></div><!--QuoteEEnd-->
kx519 Posted February 22, 2010 Author Report Posted February 22, 2010 It would most likely blow the resistor, but if you did have one that would take the power, yes it would lower your impedance, the only problem is your sub wont see the additional power you would think you should get, since the resistor is absorbing half of the total power the amp is putting out. I was afraid of that. 84 K5 Blazer 3" body, 2" Suspension 35" Maxxis Bighorn 100amp Alt Marine deep cycle for the amps (freebie) KnuKonceptz 1/0 8 Hifonics HFi 12D4's in ~19cubes tuned to 35hz Audiopipe AP-18001D RF 5x8's in the kicks Almani 5.25 comp. in back Kenwood KAC-645 --IN THE FUTURE-- None. <!--quoteo(post=0:date=Feb 3 2010, 09:12 AM:name=Decaf)--><div class='quotetop'>QUOTE (Decaf @ Feb 3 2010, 09:12 AM)</div><div class='quotemain'><!--quotec-->we seriously need some butt plugs so you guys stop spewing chit talk<!--QuoteEnd--></div><!--QuoteEEnd-->
mr.p Posted February 22, 2010 Report Posted February 22, 2010 i have 4 transformers that mmats used back in the day..... pm me if your interested i got them to make 4ohms 1 but in reality its a 3.x-1.x DCAUDIO BALLS DEEP
