Adding a second battery
So, I'm planning to put in a new system in my 2002 Intrepid. I was told I could use my stock alt and battery if I added a second battery for my system which will include an ID Q 450.4 and an ID Q 1200.1 amp. I just bought one of the HR500 batteries in the for sale section and wanted to double check how to wire it up.
The red lines are positive, blacks are negative and yellow dots are fuses. I plan on using all 1/0 for this and 250 amp fuses for it. Please let me know if there is anything is wrong or you would change it. I appreciate any help you guys can give.
Edit: I updated the photo to match the recommendations.
Edited by Reallunacy
ground to the alt aswell but everything looks great
edit- yeah fuse near the rear too
Edited by uhoh_45
R.I.P!
(Nov-29-2009)
92 explorer
current build
one more fuse before rear battery and run a ground from your alternator to frame.
name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="
type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"></embed></object>">
type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"></embed></object>" type="application/x-shockwave-flash" width="425" height="350">
R.I.P!
(Nov-29-2009)
92 explorer
current build
I personally have never ran a ground from my front batt to my rear batt I just always used a short ground straight to the frame and Ive never had a problem ....I could've been wrong all these years and if any of you guys call me on it please explain why the ground from the front batt to the rear is necessary
It's better but its fine to not run a run of wire to the rear batt if funding dont offer it...the ground at the back will do.
RE se xxx 18d2 (4)
Audioque 2200 (2)
DC Power 270XP blue
3 C&D fr310
Stinger wiring
CDT components
  • Who's Online   1 Member, 0 Anonymous, 1253 Guests (See full list)
