It's better but its fine to not run a run of wire to the rear batt if funding dont offer it...the ground at the back will do.
You say its better but ..why is it better...seems to me like the shortest ground to the frame would be strongest and a ground is a ground whether at the front of ride or the back right?
shortest ground to the vehicle is not a direct connection to the front battery so not strongest
and only as strong as the front ground
watch the video and you'll see
R.I.P!
(Nov-29-2009)
92 explorer
current build
The fewest possibly ground points leaves less room for alternator noise to get into you system.
Vehicle: 1997 S10 Blazer 4dr 4X4
Exterior: Rear End Bagged, Black Grill, Lifted 2"
Amplifiers: Rockford Fosgate T8004 & T10001bd
Batteries: 2 Stinger SPV35, Kinetik HC2400
Electrical: Big 3, DC Power 290amp Alternator w/ MLA at 15.5v
Enclosure: 4.2 ft³ @ 33Hz 84sq.in. of port (20sq.in. per cube)
Headunit: Eclipse CD3200 w/ 80G iPod
Mids/Highs: Rockford T152s (a-pillars), Rockford T162s (doors)
Subwoofers: 1 15" Fi BL Fully Loaded
Wire: All 1/0g Kicker Hyperflex
My YouTube Videos
My Fiberglass A-Pillar Build
My "Seamless" Looking Box Build
My DD1508 T-Line Bandpass Build "Seamless" w/ Acrylic Windows (for '05 TrailBlazer)
My Stealth 8" Fiberglass Build (for '05 TrailBlazer)
My Build For A Friend's '08 Cobalt 15" BL Sealed Off From The Trunk
My feedback/references...
  • Who's Online   0 Members, 0 Anonymous, 3013 Guests (See full list)
