I'm gonna be wiring 3 2ohm dv subs to mono block amp I knew how I was going to wire them until I realized the amp has 2 outputs even though its a mono block 12volt.com does not get into the specifics of this, how should I wire these? I was going to have a 1.34 ohm load before but now I am not sure.
On 4/20/2010 at 10:06 PM, 'cc_audio' said:
Guys are just like girls, once you've had 18 inches you don't go back.
2004 GMC Yukon XL
Pioneer AVH-X4700BS
13 band EQ
Sub Amp- (2) PPI 5000BD.1
(2) Re SXX 15's 8 cu. ft. box tuned to 32 Hz
(4) 6.5 Bose Mids
(2) 1" Bose Tweets
(2) 1.5" Bose Tweets
(1) JY 80 AH w/ new JY busses
(1) Duracell 750 up front
Apex Alternators 270
A.C. Delco 160 alternato
Even though you see two sets of outputs, they still act as one. They are connected internally. They just do that so it's easier to connect the sub.
I understand but since this will change how I wire 3 subs how won't the impedance change? and how should I wire them because I thought I was going to go off of 1 out put like this
but off two blocks that could change right?
2004 GMC Yukon XL
Pioneer AVH-X4700BS
13 band EQ
(4) 6.5 Bose Mids
(2) 1" Bose Tweets
bump
2004 GMC Yukon XL
Pioneer AVH-X4700BS
13 band EQ
(4) 6.5 Bose Mids
(2) 1" Bose Tweets
You should still be able to run the + and - to one set of the speaker outputs and it would be the same. I have two subs wired into just one of my two sets of outputs and it's fine.
Even if you used both outputs, like was said, it shouldn't change anything.
If that's wrong, someone correct me.
id just wire it to 1 of the 2 blocks just like the picture shows. all the other block is for is to make it easier to hook up multiple subs. but the way you are wanting to run your stuff, ya id do just like the pic shows. thats how im hooking up 3 , 4 ohm single coil subs to my amps.
ok thanks guys Ill give that a shot
2004 GMC Yukon XL
Pioneer AVH-X4700BS
13 band EQ
(4) 6.5 Bose Mids
(2) 1" Bose Tweets
Just pick one positive and one negative and pretend the other 2 aren't there.
Badabing.
2002 Pontiac Bonneville SSEi
Pioneer DEH-P6000UB
Alpine SPX-17REF 6.5" components (active)
Sundown SAX-50.4
Sundown z15 (3 cubes @ 35 hz)
Sundown SAX-1200D
2006 Buick Rainier CXL AWD V8
Stock Bose system
12" Alpine Type E in aeroported box
Profile AP1000M
  • Who's Online   0 Members, 0 Anonymous, 1365 Guests (See full list)
