96saturnsl Posted February 26, 2010 Report Posted February 26, 2010 ok i have a slight problem... got a 2 channel amp and its 2 ohm stable. we have 3 single voice coil 4 ohm subs and need to find a way to hook them all up to the amp...is this possible?
El1T3Bass Posted February 26, 2010 Report Posted February 26, 2010 Yes, you can hook all of the subs up to one terminal on the box the have it bridged on the amp, I'm not sure if that's right but I've seen it be done, and I think that will wire your subs at 4 or 8 ohms, like I said not sure soo I quess just try it out wow now this just shows that smd isnt just any forum. We are a brother hood. here let me put it in retard-onix for u aareehhhh duuuurrrrr ehhh got it now? Sweet baby jesus the amount of quoting the quote above the quote in a quote is epic
Watch the bass Posted February 26, 2010 Report Posted February 26, 2010 Yes, you can hook all of the subs up to one terminal on the box the have it bridged on the amp, I'm not sure if that's right but I've seen it be done, and I think that will wire your subs at 4 or 8 ohms, like I said not sure soo I quess just try it out I delete that shit, Kranny down is right, if it would be 8 ohm woofers it would work "in the abundance of water, the fool is thirsty" Bob Marley
Guest Posted February 26, 2010 Report Posted February 26, 2010 why do you have a 2 channel amp for 3 woofers? theres no way you can wire the woofers safely on that amplifier unless you use just 2.
AUDIOADDICT02 Posted February 26, 2010 Report Posted February 26, 2010 The only way i could think of is wiring 2 of the subs parallel, then add the third one in series, which will give you a 6-ohm load(i believe)-when bridged on the amp would drop to 3 ohms....which should work just fine CHECK OUT MY MYSPACE; SOME PAINT WORK I'VE DONE: http://www.myspace.c...customcreationz DODGE RAM 1500 QUAD CAB BOX BUILD: http://www.stevemead...showtopic=48978 DODGE RAM 1500 RUMBLEBEE EDITION CUSTOM ENCLOSURE: http://www.stevemead...showtopic=48983 PREFAB REMODELING: http://www.stevemead...box-remodeling/ G35 CUSTOM PAINTED L7 BOX: http://www.stevemead...om-painted-box/ CHEVY SINGLE CAB PAINTED SUB BOX/AMP RACK: http://www.stevemead...vy-boxamp-rack/ KICKER L512 BOX BUILT TO SPECS: http://www.stevemead...-kicker-l5-box/ RF HE2 10'S KERF PORTED BOX: http://www.stevemead...erf-ported-box/ 2 DC LEVEL 3 15'S KERF ENCLOSURE: http://www.stevemeadedesigns.com/board/topic/115502-kerf-ported-enclosure/ 2 HCCA 15'S PORTED ENCLOSURE: http://www.stevemeadedesigns.com/board/topic/129468-2-hcca-15s-enclosure/
96saturnsl Posted February 26, 2010 Author Report Posted February 26, 2010 well i have another amp its a mono amp....but idk if that will work or not...any ideas?
AUDIOADDICT02 Posted February 26, 2010 Report Posted February 26, 2010 well i have another amp its a mono amp....but idk if that will work or not...any ideas? it would work if it's 1-ohm stable... 3 4-ohm svc subs in parallel=1.34ohms CHECK OUT MY MYSPACE; SOME PAINT WORK I'VE DONE: http://www.myspace.c...customcreationz DODGE RAM 1500 QUAD CAB BOX BUILD: http://www.stevemead...showtopic=48978 DODGE RAM 1500 RUMBLEBEE EDITION CUSTOM ENCLOSURE: http://www.stevemead...showtopic=48983 PREFAB REMODELING: http://www.stevemead...box-remodeling/ G35 CUSTOM PAINTED L7 BOX: http://www.stevemead...om-painted-box/ CHEVY SINGLE CAB PAINTED SUB BOX/AMP RACK: http://www.stevemead...vy-boxamp-rack/ KICKER L512 BOX BUILT TO SPECS: http://www.stevemead...-kicker-l5-box/ RF HE2 10'S KERF PORTED BOX: http://www.stevemead...erf-ported-box/ 2 DC LEVEL 3 15'S KERF ENCLOSURE: http://www.stevemeadedesigns.com/board/topic/115502-kerf-ported-enclosure/ 2 HCCA 15'S PORTED ENCLOSURE: http://www.stevemeadedesigns.com/board/topic/129468-2-hcca-15s-enclosure/
zayres29 Posted February 27, 2010 Report Posted February 27, 2010 you really should just get a new amp cause you will either end up with 1.33333333 ohm load(parallel) or a 12 ohm load(series) my suggestion is to get a 1 ohm stable amp Btw that was the first person. Ever banned by me while dropping a deuce. Feel privileged
