make your port longer til it hits 34hz or make your port area bigger for 36hz...
146.25 is ok, 146.03 is just your minimum @34hz...
not sure what the negative number could mean...???
just keep playing with it, til it all falls into place...
so if i go bigger then 146.25 im ok right?
yeah im kind of confused abt the negative...anyone else can help with this?
ok i change the length number to 27in cames out the 34.85hz
thanks.
-CHRIS
thanks.
-CHRIS
yea, you'd be ok, as long as it's tuned @34hz....
at the bottom of the carstereo page , you could calculate port length...
34.85hz seems ok, although it's leaning more towards 35hz, especially if you're gonna brace the box & add corner fills...
CHECK OUT MY MYSPACE; SOME PAINT WORK I'VE DONE: http://www.myspace.c...customcreationz
DODGE RAM 1500 QUAD CAB BOX BUILD: http://www.stevemead...showtopic=48978
DODGE RAM 1500 RUMBLEBEE EDITION CUSTOM ENCLOSURE: http://www.stevemead...showtopic=48983
PREFAB REMODELING: http://www.stevemead...box-remodeling/
G35 CUSTOM PAINTED L7 BOX: http://www.stevemead...om-painted-box/
CHEVY SINGLE CAB PAINTED SUB BOX/AMP RACK: http://www.stevemead...vy-boxamp-rack/
KICKER L512 BOX BUILT TO SPECS: http://www.stevemead...-kicker-l5-box/
RF HE2 10'S KERF PORTED BOX: http://www.stevemead...erf-ported-box/
2 DC LEVEL 3 15'S KERF ENCLOSURE: http://www.stevemeadedesigns.com/board/topic/115502-kerf-ported-enclosure/
2 HCCA 15'S PORTED ENCLOSURE: http://www.stevemeadedesigns.com/board/topic/129468-2-hcca-15s-enclosure/
sound good.
yea i understand.
now all that done with i think the sub gonna run into the port since it gonna be L.
but im going to add another baffle over it so it should space it out more.
sound good.
yea i understand.
To get the best sound & avoid mounting depth problems, locate the sub as far away away from the port opening...otherwise, like you said, just add a spacer...
No problem! :)
Looks like it'll work just fine, good luck on your build!
Edited by AUDIOADDICT02
Sorry for the multi-post, internet's actin funny.. :/
  • Who's Online   0 Members, 0 Anonymous, 1058 Guests (See full list)
