Chris661 Posted March 2, 2010 Report Posted March 2, 2010 hello all!. my question is this all correct. port area port range..ect. BTL 18 fully load. thanks -chris Quote http://www.youtube.com/user/EAZYCHRIS?feature=mhee
AUDIOADDICT02 Posted March 2, 2010 Report Posted March 2, 2010 (edited) That's like a leaking sealed box 4 that sub...! your minimum port area 4 that sub @34hz should be 146sq.in. Edited March 2, 2010 by AUDIOADDICT02 Quote CHECK OUT MY MYSPACE; SOME PAINT WORK I'VE DONE: http://www.myspace.c...customcreationz DODGE RAM 1500 QUAD CAB BOX BUILD: http://www.stevemead...showtopic=48978 DODGE RAM 1500 RUMBLEBEE EDITION CUSTOM ENCLOSURE: http://www.stevemead...showtopic=48983 PREFAB REMODELING: http://www.stevemead...box-remodeling/ G35 CUSTOM PAINTED L7 BOX: http://www.stevemead...om-painted-box/ CHEVY SINGLE CAB PAINTED SUB BOX/AMP RACK: http://www.stevemead...vy-boxamp-rack/ KICKER L512 BOX BUILT TO SPECS: http://www.stevemead...-kicker-l5-box/ RF HE2 10'S KERF PORTED BOX: http://www.stevemead...erf-ported-box/ 2 DC LEVEL 3 15'S KERF ENCLOSURE: http://www.stevemeadedesigns.com/board/topic/115502-kerf-ported-enclosure/ 2 HCCA 15'S PORTED ENCLOSURE: http://www.stevemeadedesigns.com/board/topic/129468-2-hcca-15s-enclosure/
Forevrbumpn Posted March 2, 2010 Report Posted March 2, 2010 (edited) to damn big what are you running, 100 watts? I personally love long ports in daily boxes, and that port area would be fine in a 6 cf box, just longer port edit: I seen the wrong number for airspace, but still even 9.8cf pretty big for just 1 BTL 18 1 Pair would be fine, but again, change the port Edited March 2, 2010 by Forevrbumpn Quote I have a ritual called "terminator". I crouch in the shower in the "naked terminator" pose. With eyes closed I crouch for a minute and visualize either Arnie or the guy from the 2nd movie. I then start to hum the T2 theme. Slowly I rise to a standing position and open my eyes. It helps me get through my day. The only problem is if the shower curtain sticks to my terminator leg. It sorta ruins the fantasy.
Marlo Stanfield Posted March 2, 2010 Report Posted March 2, 2010 How much power are u running?? Why did u design the enclosure to be nearly 10ft3 after displacement?? The port area for this particular design isn't even close to where it needs/suppose to be. You only currently have 70in^2 of port area and the box calc clearly states that you should be in the range of 119-158^2. This box besides only the tuning seems to just be doomed to fail in every aspect. I'd suggest that you start over after doing a little more research into what size enclosures an 18" BTL likes. Quote 1998 Ford Explorer Eddie Bauer... New setup, old ride... QX56 is staying stock til I get loud... It's only getting walled off if I don't meet my goal @ SBN. Pioneer AVIC-N2 (12) 12" RE SXs old model.... (3) AB VFL 500.1 @ 1ohm each Dual 300amp Ohio Gen alts.... (10) Northstar NSB-125s 26ft3 @ 33hz w/ a ton of port area 156.5 @ 40hz @ dash, Db Drag style / 153.2 Bassrace
treossi Posted March 2, 2010 Report Posted March 2, 2010 what everyone else said Quote Team sundownWESTCOASTSPL.COM we're throwing dbdrag events very soon visit the website for details
Chris661 Posted March 2, 2010 Author Report Posted March 2, 2010 (edited) sorry. im still not using to makin port with torres Box cal. im use to doing it by RE cal. i just wanted to try something different. well i figure go big or go home. as from the site (fi audio) saying 5-10cuft. ported box. im running rockford fosgate t2000.1bd let me ask again. can anyone give me a design that is best with the sub. hw much room i got to play with. H34 W46 D14 nothing over that. thanks chris Edited March 2, 2010 by Chris661 Quote http://www.youtube.com/user/EAZYCHRIS?feature=mhee
Chris661 Posted March 2, 2010 Author Report Posted March 2, 2010 (edited) sorry for double post. jst mess around abit more. hope this one look better then the first. re box cal. if this good port for the sub i will be going this one. PS box is going chevy s10 ext cab. thanks -chris Edited March 2, 2010 by Chris661 Quote http://www.youtube.com/user/EAZYCHRIS?feature=mhee
kl0wn Posted March 2, 2010 Report Posted March 2, 2010 (edited) Says the depth of the box is only 14, then the port length is 20...you need to click "Check if Port Bends" Edited March 2, 2010 by kl0wn Quote 06 Mini Cooper S Sundown, SoundQubed Cadence, XS Power 151s Sealed 155s Outlaw Windshield @ 37hz
