I want to run the Audioque 1200d
to two 12" Alpine Type R's
I would like to keep the subs as long as possible but is running these subwoofers on this amp going to make them more likely to blow?
I am most likely going to keep the amp and subs as what id like to buy but does anybody see anything wrong with this setup?
Should i run these at 1ohm or 4ohm?
Edited by Habit
subs will be fine on that power i h had one 10 on over 1000rms and it was fine.. but it was clean power
1998 gmc extd cab
12 crossfire C710s
4 SAZ-4500s
3 Singer 400A alts
buncha mids/highs
Team Asshole
i edited the post right after you posted.
do you think 1ohm or 4ohm?
Agreed you will be fine. Just be smart.
Eclipse cd7000
Is it cool to mount the amp on the sub box?
The rs will be more than fine at 1 ohm if you are smart about it you should be able to run a single off an aq 1200 @1 ohm. You will be fine all day. Depends I wouldnt personally mount the amp on the box because in some cases it can be bad for the amp if your gettin some serious rattle but my old aqs rattled if they werent sitting on something soft , the bottom plate liked to rattle a bit.
2012 silverado ext cab ltz
24" kmc rims
AudioQue 2200
Pioneer AppRadio
Alpine mrx f35 4 channel
Bose mids and highs
Iraggi Alt + stock alt in a DC power dual alternator kit
Yellowtop+stock under hood
0 gauge Knu wire
Big 3
4 gauge stinger (4 chan wiring)
3 DC 10'' LVL3 with LVL4 parts
  • Who's Online   0 Members, 0 Anonymous, 552 Guests (See full list)
