ok im building a new box should i put subs up port back, sub up port up, or subs back and port back thanks
and whats the best tuning frequency so it will hit the hardest????
I SCAM PEOPLE OUT OF MONEY... AVOID ME LIKE I AM AN AIDS INFECTED RETARD...
4 kickers in that tahoe?
i'd do subs up port back.. i've never seen anything else in a truck... and i've never seen port up ever. lol.
and .. "hit the hardest" .. depends on what hard is to you. the lower it is, the lower the box peaks. i personally like boxes at 27Hz-29Hz .. but that's low for some other peoples tastes. higher tuning freq would make it louder but it makes the box not be able to play as low.
so it all depends on your personal tastes...
and someone on here could probably describe tuning frequencies better to you i'm sure
Posted (edited)
yes i have 4 kicker Cvr 12s (soon to upgrade to 6)
ok so ill do subs up port back :) but whats should i tune it to cuz i like it where it just shakes the shit out of the car and all the cars around me ha so what would be best
Edited by zachfowler222
yes i have 4 12s (soon to upgrade to 6)
LOWS! 34hz should do the trick...!
CHECK OUT MY MYSPACE; SOME PAINT WORK I'VE DONE: http://www.myspace.c...customcreationz
DODGE RAM 1500 QUAD CAB BOX BUILD: http://www.stevemead...showtopic=48978
DODGE RAM 1500 RUMBLEBEE EDITION CUSTOM ENCLOSURE: http://www.stevemead...showtopic=48983
PREFAB REMODELING: http://www.stevemead...box-remodeling/
G35 CUSTOM PAINTED L7 BOX: http://www.stevemead...om-painted-box/
CHEVY SINGLE CAB PAINTED SUB BOX/AMP RACK: http://www.stevemead...vy-boxamp-rack/
KICKER L512 BOX BUILT TO SPECS: http://www.stevemead...-kicker-l5-box/
RF HE2 10'S KERF PORTED BOX: http://www.stevemead...erf-ported-box/
2 DC LEVEL 3 15'S KERF ENCLOSURE: http://www.stevemeadedesigns.com/board/topic/115502-kerf-ported-enclosure/
2 HCCA 15'S PORTED ENCLOSURE: http://www.stevemeadedesigns.com/board/topic/129468-2-hcca-15s-enclosure/
34Htz unless you're in a audio comp burping then you don't need anything lower.
1998 Plymouth Voyager (daily)
Jensen VM9213 H.U. (I Know but I havent had any problems.... yet)
5.25" Factory -> Sound Stream SST5.2
6x9 Hifonics ZXi 693 -> Sound Stream SST6.9
Amp: Class D: Crescendo 3KWP (x2)
Class A/B: Crescendo 1000C4
Sub: Almani S-7 10" (x6)
ok thanks for the fast replys
and can you guys tell me if i would have enough to pull a hair trick with 4 12s, 3000watts, subs up, port back, and tuned at 34hz
thanks in advance
thanks in advance
Pretty sure it would be enough, a guy at a local shop has an expedition with 4 12's on 3200 watts & you could feel the air moving with the passenger door open...[subs up, port back]
HA thanks
i just pull a small one at the least but im going to build my box sometime this week so ill let u all know if i can pull the hairtrick hopefully it will at least a little:)
JL audio's w7 H/O box has the port on top going up.
2006 Malibu Maxx SS
4 sa 12's D2
2 audiopipe 3k's
4 UPS batteries
2 runs of 0awg
Walled at 34hz
How does a sport like this do in tough economic times? Just fine. There are 465 events listed in the current season. "Our competitors can't even spell recession," says dB drag racing impresario Wayne Harris. "They're young, and some of them still live at home. They put all their energy and money into their cars. They're competitive. They're at that age."
  • Who's Online   1 Member, 0 Anonymous, 670 Guests (See full list)
