Boon Posted March 10, 2010 Report Posted March 10, 2010 You denying an alternator upgrade is like saying.. okay! moving to 16 volt batteries and charging them @ 19volts won't help you get any louder!! More voltage.. less amperage demand.. more power? Downsides? I can't think of any... Let me see... you have to buy a huge stack of quite expensive batteries and then run a split charging system for the rest of your car. Why bother when you can get enough power at 12v to launch the cone out of any woofer you care to name. 16/18v is for people who are running out of space/weight to cram more power in. For the cost of making the switch to 16v I could probably get almost double my current power at 12v... and not worry about my amps running hot... 10.x volts fo' life!
skittlesRgood Posted March 10, 2010 Report Posted March 10, 2010 where are you guys measuring voltage? at the front batt, rear batt, or at the amp? i only go into 13v at the front batt but at my amp i go into the low 12s - high 11s. so im basing my electrical needs on what the amp sees. If I answered you in a well mannered, informative way, you asked a good question or had a good attitude. If I was an asshole, you asked a stupid question or you had a fucktard attitude... or I was in a bad mood. Team BassickHU: Pioneer AVIC Z110Front: Peerless SLS 6.5", Peerless HDS 4", Rainbow tweeter - running activeAmp: JL HD600/4 and DC 4 channel (bridged to midbass)Processor: JBL MS-8Subs: 2x 12" AA MayhemsAmp: DC 3kElectrical: DC power 270xp alt. 1/0 big 4. XSpower D3400 and six D680s. http://www.stevemeadedesigns.com/board/topic/121795-29-update-the-buick-is-getting-a-rebuild/ Top career scores: DBdrag 151.7 MECA SQ 82.25My SOTM build Yeah. im pretty sure they dont warranty retarded people.
Soulman07 Posted March 10, 2010 Report Posted March 10, 2010 Let me see... you have to buy a huge stack of quite expensive batteries and then run a split charging system for the rest of your car. Why bother when you can get enough power at 12v to launch the cone out of any woofer you care to name. 16/18v is for people who are running out of space/weight to cram more power in. For the cost of making the switch to 16v I could probably get almost double my current power at 12v... and not worry about my amps running hot... You completely missed the point though.. I wasn't SUGGESTING he made the switch to 16v or get another alternator. I was only pointing out the fact that more voltage is helpful with being able to supply demand. It would help produce more power so your equipment will thank you for it and also your amperage demand would be a lot less. Whether you are holding it at 12,14,16,18 or whatever voltage you have is irrelevant to what I was saying really if you stop and think about it. More power is what we crave being bass heads.. some load up on batteries if their cars limit them on the amount of alternator/s you can install. Others would prefer getting a decent size alternator and save the battery space for more subs and amps. I know you were sharing a bit of knowledge about the whole 16/18v systems so I ain't shooting you down in any way shape or form. I was just trying to help him get a bit better of an understanding of how things work. We'll all have our own standards and preferences when it comes to doing something. So we aren't really here to win each other over... most people form decisions based off of the input of many, not just one person in particular. Whatever route you decide to take is up to you in the end though. 1993 Chevrolet SWB Pickup Viper 791XV Primer Stage 5/8 Static Drop Kinetik HC1800 Big 3 Knu Flex 0 Team Tex Flex
moh.vze.com Posted March 10, 2010 Report Posted March 10, 2010 i had the same power, same battery but with a 120amp alt. my lights dimmed so much they almost turned off. never measured voltage but it must have been 10's. so i have to completely disagree with the "no ho alt" argument. my car definitely needed one. hmm. Interesting DC Audio - Singer Alternators - Knukonceptz - XS Power - Hybrid Audio - Rockford Fosgate - Second Skin Audio - SMD - Sundown Audio - Elemental Designs
moh.vze.com Posted March 10, 2010 Report Posted March 10, 2010 bingo stock 105a 03 grand am valeo alt spv35 in back and front 4g on an re12.1 w/big3 and i saw 10v all the time if u dont have voltage drop u dont have ur gain set right moh.vze, lol... to get 1400w u need over 100amps of current draw and theres no way unless u play quiet songs I am pretty sure I have my gains set correctly. I used an oscope to tune everything. One of my amps is 1200 watt rms for the subs and the other amp is for the DLS MS6A components which is only getting about 200 watt rms total. (Or does it not work like this? More strain if it's 1400 watts rms for subs rather than adding the two powers?) My voltage idles at 14.5V engine on and drops to around 13V avg on fulltilt decaf music. Edit: actually I was listening to all of your tracks on your decaf zip 11 today and my voltage did drop to 12.7V range sometimes. That zip is probably one of your best DC Audio - Singer Alternators - Knukonceptz - XS Power - Hybrid Audio - Rockford Fosgate - Second Skin Audio - SMD - Sundown Audio - Elemental Designs
loganberry Posted March 10, 2010 Report Posted March 10, 2010 i ran a stetsom 2kd in a ford excursion, stock alt stock batteries, voltage was horrible alt was only 130 amp, dropped crazy low, but it played fine for over a year before i sold the amp My F-150 Build GET ON THE BANDWAGON what if they tried messing with the amps when the subs werent louder hahah jk
moh.vze.com Posted March 10, 2010 Report Posted March 10, 2010 where are you guys measuring voltage? at the front batt, rear batt, or at the amp? i only go into 13v at the front batt but at my amp i go into the low 12s - high 11s. so im basing my electrical needs on what the amp sees. I only got 1 batt but I remember calibrating my stinger voltmeter (wired to the amp in the trunk) to match the voltage of what my DMM said in the front battery. DC Audio - Singer Alternators - Knukonceptz - XS Power - Hybrid Audio - Rockford Fosgate - Second Skin Audio - SMD - Sundown Audio - Elemental Designs
moh.vze.com Posted March 10, 2010 Report Posted March 10, 2010 i had the same power, same battery but with a 120amp alt. my lights dimmed so much they almost turned off. never measured voltage but it must have been 10's. so i have to completely disagree with the "no ho alt" argument. my car definitely needed one. Clipped music probably DC Audio - Singer Alternators - Knukonceptz - XS Power - Hybrid Audio - Rockford Fosgate - Second Skin Audio - SMD - Sundown Audio - Elemental Designs
xtremeacoustiks Posted March 10, 2010 Report Posted March 10, 2010 I actually still have my stock alt. with four batteries with the 2 ap30001ds and 2 ap2004s with the big 3 of course but I was at a show demoing and i stuck a quarter in my throttle bar and kept the engine at about 2 thousand rpm's and at the batteries in the back I was chargine at 14.9 volts and at full tilt never dropped below 13...not sure what size alt i have from the factory but it seems to work just fine for me www.bassproducers.com TEAMS TEAM BASSPRODUCERS, TEAM HERTZ (VA) *Ranger System* (4) 18" Kicker Comp (4) 10" Kicker Comp Dual Stinger Alts. (5) Rockford Punch 200's (2) Punch 100's *Outlander System*152.6 DB so Far* ( TXX-APX12W (2) AP-30001D'S (2) AP-2004'S ( APMB6'S (4) KHC2400'S
Boon Posted March 10, 2010 Report Posted March 10, 2010 where are you guys measuring voltage? at the front batt, rear batt, or at the amp? i only go into 13v at the front batt but at my amp i go into the low 12s - high 11s. so im basing my electrical needs on what the amp sees. I get the same voltage give or take 0.2 or so throughout my system... either your wire is too small or you're losing a bunch of voltage somewhere... go through the system with a multimeter and find out where you're losing it. Your electrical system should be like one big lump of copper, same voltage front, rear, at the pad where the power supply MOSFET is attached to the PCB... 10.x volts fo' life!
