imupabove Posted March 11, 2010 Report Posted March 11, 2010 anyone have any experience with this amp? or know if its any good/bad? does it really put out the watts it says it does? thanks. SPECS:* LANZAR OPTI1400D 1400 Watt Car Digital Amplifier * Mono Block Subwoofer Amplifier * 1 Ohm Stable * MOSFET Power Supply * PWM (Pulse-Width-Modulated) System * Double Sided Epoxy PCB Circuit Board * Gold Plated RCA Inputs * Custom Terminal Block for Speaker Connections * Thermal, Overload & Short Protection * Remote Bass Control * Soft Turn On/Off * 500 Watts RMS Power into 4 Ohms * 800 Watts RMS Power into 2 Ohms * 1000 Watts RMS Power into 1.3 Ohms * 1400 Watts Max Power into 1 Ohms * THD @ 1Watt/4 Ohm: 0.1% * S/N Ratio: 90dB * Frequency Response: 15Hz - 150Hz (+/-3dB) * Damping Factor @ 20Hz/4 Ohms: 400 * Variable Low Pass Filter: 50Hz-150Hz, 24dB/Octave * Variable Subsonic Filter: 15Hz-40Hz, 24dB/Octave * Variable Bass Boost: 0 to +18dB * Phase Shift Control: 0 to 180 * Input Sensitivity: 200mV ~ 8V * Input Impedance: 10k Ohm * Line Output Impedance: 100 Ohm * Fuse Rating: 30A x 4 * Dimensions: 10.08'' (W) x 2.12'' (H) x 14.96'' (L) iDA-X200/Clarion EQS746 RF T500-1bd (2) 12" RF HX's Kicker 350.4 Alpine & Polk Speakers Stock electrical
Watch the bass Posted March 11, 2010 Report Posted March 11, 2010 The Opti-series, is the highqualityseries from Lanzar and got good critics, u can trus them. "in the abundance of water, the fool is thirsty" Bob Marley
imupabove Posted March 11, 2010 Author Report Posted March 11, 2010 The Opti-series, is the highqualityseries from Lanzar and got good critics, u can trus them. really. i dont see that much people rockin Lanzar, but i heard few good things bout the OPTI series. you think they underrate their amps? i can get one for $140, good deal? iDA-X200/Clarion EQS746 RF T500-1bd (2) 12" RF HX's Kicker 350.4 Alpine & Polk Speakers Stock electrical
n8ball2013 Posted March 11, 2010 Report Posted March 11, 2010 its not a bad deal at all should do rated. I believe they are very similar to soundstream. THERE IS NO BUILD LOG! 1998 Chevy Silverado ext cab Alpine CDA-9887 4 Team Fi 15s 2 Ampere Audio TFE 8.0 2 Ampere Audio 150.4 3 Digital Designs CS6.5 component sets Dual Mechman 370XP Elite alternators inbound! 8 XS Power d3400 6 XS power d680 Second Skin Stinger Tsunami Wiring Sky High A Real Voltmeter not a piece of shit stinger.
Twistedchild420 Posted March 11, 2010 Report Posted March 11, 2010 its not a bad deal at all should do rated. I believe they are very similar to soundstream. This......same boards on their bigger Opti's as the XXX series......good deal for 140$ My POS Bass machine-2003 Hyundai Santa Fe on some shitty 22'sBed Liner Paint Job-Pioneer AVH 3200DVD4 DAD BD series 15's in a 4th Order (Bassheads ENT Design)4 Arc Audio XDI2000.1 for the woofers6 Cadence CVL68MBX 6.5's-Cadence CVL88MBX 8's-6 Cadence XT20 Supertweeters2 Arc Audio KS300.4's for mids and tweets1 Arc Audio ALD 10v Line DriverAll Audiotechnix Power wire1 DC Power 270XP High Output Alternator1 XS Power D3400 up front....6 XS Power D3100's in the rearAir Lift 1000 Bags in rear to help with suspensionIf your still reading this GFY.......
