tma 500.1 keeps going into protect
Thomas
Well heres the deal.Im currently running my back up gear in my car which consists of a CVR 15 and a TMA 500.1. The sub is a dual 4 ohm wired in parallel into the mono block tma.Well the problem is that the amp keeps randomly slipping into protect mode.Its not getting hot and comes right back on when i restart it.The amp is 2 ohm stable,I have the gains set less than half way,Im not cranking on it too hard,and the wiring is adequate.
I cant come up with any other reason why it would be going into protect.Ive checked everything i can think of...
Ground is good, positive and negative speaker wires not touching anywhere,running at 2 ohms,not overheating.Anybody have any other ideas?
I should add that i have had very bad luck with tma amps so far so it wouldn't surprise me if the amp is just faulty.I originally bought two of of these amps, one of them was broken right out of the box but i got it replaced.I ran them both for about 6 months then one of them randomly stopped working out of nowhere.It powers up light and all but makes no noise and gets VERY hot to the touch within minutes. I knew these amps were junk when i bought them.
can you contact JL tech support? since you have been having issues with them ma by there something they can do for you. what kind of warranty do those have?
2007 Chevy Impala LS
1 Crescendo 3KWP
1Crescendo C1000/4
2 DC lvl 4 15's with lvl5 dual .7 coils
1Audio Control Matrix
1 Pioneer P880PRS
1 300 amp Iraggi alt
All power runs done with Knu flex 0/1 guage
1 optima yellow top under the hood
1 XS 5100 and two Deka's in the trunk
4 Crescendo MP-8 mid bass drivers
2 DB Drive p5 5 D Pro Audio tweeters
hows your ground?
R.I.P!
(Nov-29-2009)
92 explorer
current build
What kind of signal voltage are you sending it? I heard TMAs can't handle shit for RCA voltage.
My deck has 4 volt outs.
hows your ground?
Ground is good.
hmm... if your deck goes to .. say.. 50.. try tuning it with a max with your deck at 30. your component speakers will be really quiet but it'll test if the TMA amp can't handle the high(er) RCA voltage
