remove system
install outside of car
if noise is gone, reinstall and dont take any shortcuts. if its not gone, your car is haunted. call the local exorcist or sell it off. by isntall out of car i literally mean out of the car. deck, speakers, wires, amps, on the damn driveway wired directly to the batt ( with a fuse ofcourse). this eliminates the equipment as the source of noise and narrows it down to the car or the install. if it works out of the car, and its installed properly (rcas far from all sources of power, GOOD grounds to chassis for everything, grounded rca's, no shorts) then you just have a haunted car.
Team DC
remove system
I guess so. I'll just mount the box to my driveway and lay in the yard to listen. Oh well. thanks everyone.
God damn its hot today. My balls are stuck to my leg.
isn't there some sort of foil shielding I can purchase? Either that or beat the fuel pump senseless with a hammer.
run wires through the headliner if theyre getting too close to the fuel pump.
Edited by finkster
Eclipse cd7000
tried that. I hear this noise in my dreams. It is getting annoying. It's as if the car audio gods are laughing at me.
your not the only one buddy. ive been spending months trying to fix my noise and have not yet found a solution.
Custom Car Audio
(815) 916 - 9194
www.midwestsplcustoms.com
2000 Tahoe | 22" GREED Celebrities
Alpine CDA-117
Dual 0/1 Runs
(3) 925 CA Group 31 In Back
(4) 18" FI Audio Q's (W/ Extra Spider)
(4) Hifonics BXi 2010D
Hifonics ZXi 4410
4 RF P1653 6 1/2's
Big 3
All Kicker/Knu Wiring
if there were wires touching you would know lol...you wouldnt have speakers anymore :D
mine didnt blow up when it happened to me. although i didnt have it like that for years
damn lucky. took my xxx mid less than 5 seconds...of course that was positive touching negative and ground at the same time. fucking loose screw somewhere under the carpet. freak accident.
Edited by finkster
Eclipse cd7000
Check your grounds maybe? Because I know if my amp grounds get even a little dirty I get hella engine noise. Go OCD on that shit and see if it helps at all.
Too many projects, too little time...
remove system
He's right. It's time consuming... but I had a a negative speaker wire touching the door once in my 96 monte carlo... passenger side... couldn't ever figure it out, so just logically went through everything until I got to the front mids... and sure enough. the wire that went into the terminal was stripped too much so it came out of the terminal and touched the door panel. I even heat-shrink all my female speaker terminals in clear plastic so this wouldn't happen.. but what do you know =/
Good luck bro!
  • Who's Online   0 Members, 0 Anonymous, 2830 Guests (See full list)
