95 civic. I have horrible engine noise with or without ground loop isolator. Worse without isolator. Tried groundg rca shield to radio, chassis, battery. Tried power line noise filter. I get interference with car ignition switch on, but without motor running. If i turn blinkers or hazards on, I hear it through the speakers. If i crank car it is much worse, almost like 2 different noise sources. Unplug rcas from head unit noise is still present. If i insert a mute plug in rca, the noise is gone. This is with three different amps, new and used. When i grounded the rca shield to the radio, it gets worse. Part of the noise seems to come from the fuel pump under the back seat. If i get the wires away from it, it reduces it, but not enough. Help!!!
God damn its hot today. My balls are stuck to my leg.
Had the same prob in wifes 01 Accord we even switched to Street Wires ZR 9 RCA's, never figured it out. Sold it!
Edited by coyotechromez
i remember reading a few days ago, that where the speakers where screwed into the door, was causing the engine noise cause it was acting like a ground r some shit ..:/
just a thought ... are the screwed to the sheet metal in the doors?
2006 F-150
XS Power
4 DC 3.5kw
Team DC
Team S.P.L.
Lot of Audio Technix and 1/0
DC Audio Dealer
American Bass Dealer
XS Power Dealer
Audio Technix Dealer
Is it a Pioneer radio?
12" DC LVL 4
Sundown 1200D
PG RSDs
PPI PC2100
Alpine 9886
did you try a different hu? Are speakers run off amp or hu? Maybe try replacing rcas
Team NWSPL
baaudio Build Log
2001 GMC Sierra walkthrough
4 Mechman Elite 370s, 10 AGM batteries, 3 Crossfire XS v2 18s, Crossfire 8k
speakers are on a 4 channel amp. No rears only front. Fronts are mounted to a wooden plate to keep from hitting window. It is a Pioneer radio, but I get the noise with rcas unhooked from radio. Tried different head units, different amps. I have gone through every noise troubleshooting checklist I can find. I tried isolating the switched power lead from vehicle with a relay. No help. Had noise with factory alternator and HO alternator.
Has each different HU you tried been different than a Pioneer? Pioneers are notorious for the engine whine...
12" DC LVL 4
Sundown 1200D
PG RSDs
PPI PC2100
Alpine 9886
  • Who's Online   0 Members, 0 Anonymous, 2682 Guests (See full list)
