I have an D3100 under the hood and just got my D3400 to put in the back. How should I wire it can I just run an power wire from the front to back then ground the back battery to the chassis? And would mt current 4gauge wire be ok for now?
XS Power D5100, 2 D2700s, & 2 D975s
MechMan 220a Alt
DC 5K
Kicker 650.4
2 12 Ascendant Audio Mayhem's
Pioneer DEH-P7200HD
Rockford Fosgate 3sity.1
Build log: https://www.stevemeadedesigns.com/board/topic/166792-88-nissan-maxima-trunk-build/#entry2430899
https://www.stevemeadedesigns.com/board/topic/191439-lexus-is300-fi-crescendo-shca-rf-pics/
When i was told how to do it they said that the B+ run from the front batt to the back batt needs to be fused at both ends, but i dont qite understand why... explanations??
Edited by 99xtremedime
a0xp5g.jpg-2 AQ HDC3 15's-'Nendo 3KWP @ .5-7.75cuft @ 30hz-Alpine CDA-117-4 Cadence PA 8's
-AQ 200.2-2 AQ Supertweeters-XS Power D3400-270a Mecman Alt
-Knu Konceptz Wire
I think they meant from the front bat to the back bat then from the back bat fuse to the amp.. That is because if your front bat or alt take a dump you won't blow your amp up. So it's like BAT----FUSE----------------------BAT----FUSE------amp
BUILDLOG
http://www.stevemeadedesigns.com/board/ind...showtopic=61862
"98crewcab"Never a POS....just always "a work in progress" lol that's how we roll bitches!!!
Your a lowlife kid. I bet your mother wants to kill herself for not swallowing your ass.
you fuse it at both ends cuz if it ever draws too much current, it has a better chance of popping the fuse at either end, then starting a fire. also you can either ground it on the chassis or run a negative...some people prefer to run a negative so they have a good connection.
AA-Atomic-Clif Designs-DC-Diamond-Digital Designs-Directed-Eclipse-Fi-Hertz-Hifonics-Kenwood-Memphis-Phoenix Gold-Pioneer-PPI-PSi-Stinger-Sundown-TC Sounds-Viper-Zapco
ok so see where i get confused, 2 replies saying two different things. Is 2 fuses between the front and back B+ really necessary?
-Knu Konceptz Wire
necessary? not really. but safe? yes
  • Who's Online   0 Members, 0 Anonymous, 6869 Guests (See full list)
