lets say you build a box that's bigger than recommended by the manf., but the port is big enough and tuned really low like 28hz.
what happens to the efficiency of the box as in watt handling. does port area need to increase/decrease? can it hurt the sub?
Point to this is i built a box for a Philips home 8" today that came out of a all in one home theater kit> surrounds, dvd player, and sub. the dvd player(the brain) died but i still had the sub which was useless with out the brain telling the amp in the box what to do. from what i can tell the old box is 9x9.25x14 .5mdf and tuned to 50ish hz. with 4.9"2 port area at .5ft3 net volume
the one i built is 9x13x20 .75mdf and tuned to 28hz with 5.16"2 port area (2.25x2.25x17)port at .98ft3 net.
??? I was thinking i was building it for a future sub to go in and use this one for now. maybe a sundown 8" or something beefy.
what do ya'll think it would sound like with just a 300.2 on it? i don't even know the ohms load? Thinking about trading my GF her 600.2 kenwood for the box, sub, and my boss 300.2 chaos craptastic amp. i think it'll sound good at moderate levels just not with lots of power(hense the amp swap)
Edited by JMZNeal
JVC AVX-44 and 360.2
Subs: 2 RF T1 12s 1ohm mono off a RF T1500bdcp 80hz \/ in a 2.3cube 45hz slot port
Mids: 2 O2 8's off a Punch 550.2 behind seat, 2 Image Cxs 6.5's and 2 ID XS 6x9s 80-3khz in doors on a T600.2
Highs: 2 ID CD.1 MH HLCD 8ohm off a RF 400.4 3khz /\
too big means less power handling for the woofer. and why the hell do you want a 28hz tuning?
as the box area increases power handling decreases, as there isnt much back pressure on the sub.
Edited by finkster
Eclipse cd7000
Throw a voltmeter on the coil(s) set to ohms to check the ohm load
Team NWSPL
baaudio Build Log
2001 GMC Sierra walkthrough
4 Mechman Elite 370s, 10 AGM batteries, 3 Crossfire XS v2 18s, Crossfire 8k
why not? The Iceman is tuned to 22Hz.
TNCB
....my damn room was shaking, im like wtf is this how am i gonna die jakin off to vida guerra?
ice man isnt running a single 8 ripped out of a HTIB that went bad...
.5 cubes should be fine for a normal 8, but dont expect the one you have to take any sort of real power, especially in a different box
Team DC
hahaha. true.
i say try it out. learning experience! :drink40:
TNCB
