2 Stroke Spark Plug Color?
the thing is, the spark plug isnt instant. it takes a few hours of riding for it actually to set in. the plug is kinda like your oil dipstick. you know you put the right amount of oil in there, you just wanna check and make sure a month down the road. you kinda have to go by the seat of your pants and how its running to tune it, and hope it ends up in the right spot. I've built and played with everything from 2 stroke r/c cars to gopeds to dirtbikes and quads and even 2 stroke boats, and if there is anything i've learned its that there is no foolproof way of tuning, and even if you get it perfect, if you go out tonight when its cold out you'll be off again and have to richen it up...
Team DC
hmm wow. i never knew that. that explains why when i changed the high screw a little (1/4 turn at a time) then rode it up and down the block at WOT, the spark plug looked exactly the same.
yea, its not an instant indicator. the only time it can be is if you run waaaay too rich, the plug will actually be wet...and the motor wont be working well at all.
you kinda have to play with it, but in all honesty dont be scared if you find the screws are at drastically different settings. i know with gopeds i kinda just put them both all the way in, backed low out 1.5 and high out 2.25 and then tuned from there (and sometimes ended up with like 1 on the low and 5 on the high...) weather, humidity, gas octane, the exhaust pipe, barometric pressure, elevation, all cause changes to the exact fine tuning.
Team DC
to add onto what raytard has told you.. what i was doin with my nitro truck ( pretty well the same thing ) get it started and have it warmed up and up to normal operating temp. before you start adjusting anything. go to the low end first and have it set so that you can open it wide open without it bogging or sputtering. if its to lean it will bog and if its to rich it will do the same thing. then once that is good you can set the high speed now if its in a spot you can reach safely while driving you can go for a drive and adjust it till it pulls hard and hits max RPMS ( or sounds like its about to blow ) and then try and find the sweet spot by going by 1/8 turns in and out to see what is better.
and its a 2 stroke engine you always want a little bit of smoke coming out of the exhaust.
can the low screw help the bike idle better? because it cant idle at all as of right now but drives decently fine.
edit: oh yea and when i get the bike to the best settings that i can, will there be smoke coming out? because theres absolutely none the way it is now.
You need to clean your carb and all the jets.. everything. Take it to a pro to have this done as setting idle/run jets can bit a bit of a pain and you dont want to burn the motor up...
Hammerdown... 1%
easiest way to bump the power up on that will be to put the thinnest head gasket you possibly can
the thinner you get it, the more compression the motor will make
also, do some research on the coil. if you can find a way to push more power through the coil, you can open the gap up on the spark plug. which will create a better stronger spark.
then you can start dumping more fuel into it.
edit: once you get it making a lil more power, then you can throw a bigger sprocket on the crank. with more power, it will accelerate about the same as it does now but your top end will be alot faster
I used to ride motocross and play with motors... Spark plugs come with a white colored electrode like that brand new. When they get a creamy milkshake color going to em, that means it's a little rich. You'll usually foul out a plug if it gets bad enough. A fouled out plug could make the bike start harder, run more sluggish and sometimes die or won't start at all. That's usually when it turns visibly brown. I'd say you're a little too lean, so add a little bit more oil so you don't lock the motor up! A little more is better than not enough because plugs are cheaper than motors and after all, it's a 2-smoke!
2003 Ford Crown Victoria P71
2 12" Kicker CVX's
Audiopipe AP15001d
Stinger SR80 Isolator with DieHard 1200CCA battery
Streetwires 0awg
Secondary - 1998 Ford Expedition XLT
