a cheap alternative to dynamat and all the other overpriced deadeners, is called peel-n-seal. Its available at Lowes and some home depots might have it. It's used for roofing, just clean the bottom side of your deck lid, I like to use a rag with a little bit of paint thinner/reducer.
No, the thinner will not make your paint come off btw...just get it clean and let it dry, then start putting on the deadener of your choice. The one I named will be more then enough to stop your trunk, and its under $15 for a nice sized roll.
Despite what will be said about it "falling off" or "stinking" none of that is true. I have it it for a few years, in both freezing and 100+ deg summers. Not a single problem and I never smelled it once, my new sub box had more of an odor because of the fresh cut wood... Whatever deadener you use, just prep it well and you will be fine.
Agreed.
I use this stuff to deaden my beater everytime I pull a panel off.
Works great for what it is...
[HOONIGAN]*
'01 Ford F-250 LWB
JVC KD-R950BT / Alpine MRV-M500 / (2) SWA-10s4
If you want the easiest alternative, buy a new car, one that doesn't rattle, all you have to do then is chuck your sub in there and add a few wires. Glue and deadening is cheaper. building a new box is UNNECESSARY it's not going to change anything, the only reason it would be quieter is because sealed requires more power. If it sounds like shit anyway (if nothing is rattling) burn that prefab box and build a nice sealed one, or if you can't build them yourself, design it, then get a shop to build it to your specs.
problem solved!
My RE MT 18" wall build Former build, farewell beloved wall.In progress, Toyota Starlet build
This forum has a massive boner for ridiculous electrical upgrades.
Before you buy anything, go to secondskinaudio.com or sounddeadenershowdown.com (or something like that) and take a look.
Send emails to the owners, both answer to emails fast.
They will tell you what to do to stop the rattles.
Get all the info first.
Peal and seal may not be the solution for you. Be careful !
In résumé : fix the rattles. Forget that sealed box idea(or turn the bass down !)
Good luck
black BMW X1 2.0 l 192 hp
OEM head unit, Amplifiers Audison AP 8.9 with integrated DSP and Ampere Audio 1200.
Focal ES 100 K in front doors, and Dayton RS 180 for midbass under the front seats.
2 SSA DEMONS 10" subs, in a sealed box. SecondSkin Damplifier on front doors, and Luxury Liner Pro for the cargo area.
  • Who's Online   0 Members, 0 Anonymous, 1352 Guests (See full list)
