I just got this dei backup battery to add to my alarm system (Its a dei rattler, nothing fancy, no complaints, adding this and extra sirens this weekend).  I was under the impression that the alarm module and the sirens could be wired up to this and continue to work if the battery is disconnected.  But I read the manual and it says that the only thing it should power is the alarm module.
Lets say it can only power the module.  Well the module grounds the relay for the sirens, but if the battery is disconnected, the relay wont work because its got no 12volts.  If the relay doesnt work, then all I have is a module with 12volts doing nothing, which wont do a ting for my car.
Do you guys think this would work - Wire the two 6 tones to the relay as planned, 1 in the hood 1 in the trunk, but wire the piezos to the backup along with the module and say screw the instuctions?
where did you get te back up battery at? imy local dealer is having trouble gettin one in because hardly any one buys them?
NoFearX18 said:
trainman0978 said:
I just installed it this afternoon.  It is curently hooked up to the alarm with the single siren under the hood.  Im still not sure how Im going to handle getting 4 sirens to run off this ting....
The coolest part was that I was able to mount the alarm brain, the backup battery and the backup module all under the trim in front of the shifter.  And I rerouted all of the alarm wiring up through the dash and now the only non factory wires you see under the dash are for the dash speakers.
Guest MegaloManiac
dont ever post where your brains are fyi
I never said what/where my car is nor post pics
idiots. that guy is pretty stupid if u have read his other posts
you dont have a system and you offered no real advice to the original post, please dont waste peoples time with your opinions.
  • Who's Online   0 Members, 0 Anonymous, 1300 Guests (See full list)
