Ebes Posted April 8, 2010 Report Posted April 8, 2010 Ok so i have a woofer that decided to poop out on me and i was curious to see if i could persay buy a fi btl recone kit and use the motor from my old woofer(old woofer wasnt a fi btl). Do i need to make sure somethings are the same between the 2 woofers or what?
ssackett Posted April 8, 2010 Report Posted April 8, 2010 You can contact Fi directly and have a recone custom built. Or you can have one built by one of the builders here on the forum. Forevrbumpn can, I also make recone kits, and there is a few others that can custom build you a recone. What type of sub did you have? Team S.S.C. DB Drag Street A 2011 National Champ DC Audio Dealer Nor Cal AA Dealer Incriminator Audio Dealer CA Sundown Audio Dealer [email protected]
Brandon15zzz Posted April 8, 2010 Report Posted April 8, 2010 Message ForevrBumpin or ssackett they should be able to help you out(they build custom woofers) Hope this helps Vehicle: 1995 Impala SSHead Unit: Pioneer AVH-P4400BHMids And Highs: (still deciding)Batteries: 1 Deka Group 34 Time to make a race car.My Build Log: Solo X 12"http://www.stevemead...don15zzz-build/My Build Log: DC lvl 4 xl 15"http://www.stevemead...don15zzz-build-My Wall Build Log: 4 Lanzar 15's/ 3k+ RMShttp://www.stevemead...t-by-techforce/My Feedback:http://www.stevemead...1
tlee2 Posted April 8, 2010 Report Posted April 8, 2010 Ok so i have a woofer that decided to poop out on me and i was curious to see if i could persay buy a fi btl recone kit and use the motor from my old woofer(old woofer wasnt a fi btl). Do i need to make sure somethings are the same between the 2 woofers or what? It would help to say what your old sub is 6 Sundown X 15s 2 Sundown NS1 V2s C Pillar 4th order Bagged Suburban on 24s http://youtube.com/tlee333
Boon Posted April 8, 2010 Report Posted April 8, 2010 Ohhh man. My 2L Ford blew up. Hang on I have a great idea! I'll put CHEVY V8 PISTONS IN IT. WHY HAS NOBODY THOUGHT OF THIS BEFORE. SURELY THIS WILL MAKE MY FORD TAURUS GO LIKE A CORVETTE. Does this sound stupid to you? 10.x volts fo' life!
devil4u2c Posted April 8, 2010 Report Posted April 8, 2010 Ohhh man. My 2L Ford blew up. Hang on I have a great idea! I'll put CHEVY V8 PISTONS IN IT. WHY HAS NOBODY THOUGHT OF THIS BEFORE. SURELY THIS WILL MAKE MY FORD TAURUS GO LIKE A CORVETTE. Does this sound stupid to you? hahaha
STEvil Posted April 8, 2010 Report Posted April 8, 2010 As long as the bore is the same diameter it would work... assuming the wrist pins worked too, or the connecting rod from the chevy if not.. then thats gotta fit onto the crank. Anyways yeah, a recone can be made for your basket/motor easily. Many subs are quite interchangeable surprisingly.. MickyMcD - "Capable of making some serious trouser flapping volumes at where's-my-testicles frequencies, the Servo-Drives used to be fairly jaw dropping..." Any time you have have a power wire next to your frame put some rubber hosing (or cut up an innertube) around it. The wire is bound to wiggle (due to driving or flex) and the casing will eventually wear through. Hammerdown... 1% no links to outside websites, business related FB/YT pages allowed.
