I wanted to paint my brakes and rotors. but they are rusted so would i have to sand the rotors first or is there a paint that i can just spray them with and will stick
pioneer avh-p4200dvd (soon)
Highs amp Zx350.4, zx200.2
4 Kicker Cvx 15 D4
Sub amps (4) Zx1000.1 (need one more)
doors (6)kicker ks 650
Still under construction
they make caliper paint, any autoparts store should have it. I just spray them with brake cleaner, wiped down, then spray away. never had any problems with the paint sticking
99 suburban, ranger rover headlights, SS front bumper,roll pan with frenched tag, 2nd row delete,glassed dash..audio to come whenever I figure out what I want.
I used a metal brush which i adapted to my cordless drill to clean the rust off of the calipers first, then i soaked the calipers under metal etch to make sure i got all the rust, sprayed primer let it set and added paint from kragen auto parts.
You're gonna want to get most of that rust off before you paint them. Get a whole lot of brake parts cleaner and some wire bristle brushes.
2002 Pontiac Bonneville SSEi
Pioneer DEH-P6000UB
Alpine SPX-17REF 6.5" components (active)
Sundown SAX-50.4
Sundown z15 (3 cubes @ 35 hz)
Sundown SAX-1200D
2006 Buick Rainier CXL AWD V8
Stock Bose system
12" Alpine Type E in aeroported box
Profile AP1000M
That the first thing i should do. Sometimes i would just think buying a new one have it painted new and fresh..
if you have an angle grinder (if not you can get one for around 30 for a cheap one) you can buy a wire wheel for it and youll run through that rust in no time
