I do believe all 3 will print it out but yes you should definitely go back to one of those places and get a print out and order the parts from them. Then put them on yourself. A lot less stress and bullshit than having to deal with a mechanic who wants to screw you out of your money. Exactly why I do all my work myself.
It's a shame that some asshats have to try and screw you out of your money. If on your receipts it says it was replaced I would raise a bitch about him either not replacing it or doing so with a defective part.
Maybe take it somewhere else and see what they say, then use their opinion against him.
Too many projects, too little time...
I would do it myself but exhaust work + no lift = pain in the ass.
I went to Autozone and guess what, catalytic converter. Same shit he's been saying but decided to change today. Basically:
*Catalyst efficiency low-bank 1
Explanation:
*The O2 sensors monitor the Catalytic Converters ability to store oxygen
Probable cause:
Catalytic Converter defective (failure possibly due to #2,3,or 4)
*2. engine misfire or running condition
*3. large vacuum leak
*4. engine oil leakage into exhaust-valve guide seals, pistons rings
We have no lift and weve did plenty of exhaust work. You just have to be careful and pay close attention to what you are doing. Is there any way you could possibly jack it up and drop the exhaust, weld it up, and then bolt it back up?
I would hate to have a problem with the converter because I have two with the sensor in the center of the two.
pulling codes is all fine and dandy, but i do hope you realize that a slow reacting oxygen sensor that is still within its operating parameters can cause a cat efficiency code as well. Shop that put the cat on needs to grab a damn infared heat gun and see if the cat is even firing.
Daily Driver 1999 Kia Sephia
Kenwood DNX-893s
Audison Bit One Processor
2 Dat 4.125's
Sundown Audio SCV-6k
Hertz hsk-165xl's Mids running active        Focal V30 Series Tweeters running active
Sundown Sa-8 v1's in the doors
2 Sundown Zv5 12's
Lots of Hushmat
Big 3+ and 3 + & 3- runs of Trystar 2/0
2 Dc Power Engineering 320 HP Alts
2017 Comp Vehicle
2006 Toyota 4 Runner
Kenwood Excelon DNX-893s        Audison Bit One HD DSP
4 Sundown Sa 6.5v2 Component Sets
Focal Access 6.5 2 ways
Sundown Audio Sax-50.4        Sundown Audio Sax-100.4
2 Dc Power 370xp
Northstar agm27f
Northstar agm65
2 Northstar asmagm 480's
2 Dual 1 Sundown Nightshade v3 12's
2 Sundown SCV-7500's
All SMD Fuse Holders
Shitload Of Sundown 1/0
120 sq ft Second Skin Damp Pro
No, Its Not A Burp Truck!!!!
2016 Season 3rd place in Xtreme 1 At Finals
2016 Season 6th Place In Kaos 1 At Finals ( Blew The Subs Up In First Round Eliminations)
2 Kansas State Records Set In 2016 In Xtreme 1 And Kaos 1 In Midwest SPL
David said:
audio is a lifestyle, not a hobby
newls1
I cant read a tape to save my life... 1/2's are ok, but other marks confuse me
kingsuv
only men who cant read a tape, take it in the ass
kingsuv
you sir, get a pink hard hat on jobsites
Pm me the codes, i can do all this stuff at school and tell you what it is, obd2 is the computer they hook up to your car to run diagnostics, not like the one you can borrow at auto parts stores, but it picks up the trouble codes when your car first turns on and runs the diagnostic checks. I can take the codes from it, and check it on our program at school. If it's saying something bout the cat, im calling bs and calling it an O2 sensor
My F-150 Build (So Far)
2 DC L3 10's
Kenwood KDC-X794
(4) Selenium ST200 (Highs)
(2) RE X8 (Mids)
Sundown Sub/Mid/High Amps
Shuriken Batteries
Knu Wiring
My Feedback Thread
