head unit clipping
head units clip? or do you mean subwoofer?
edit: what I did with my setup is I put the volume at a reasonable level to which I could ride around to (not blasting) and the bass at +7 and sub level on HU at 15, then I tuned the amp and made the subs beat as hard as they could (to the point where they still sounded good tho) that way if I wanted to turn the volume of the mids and highs I would turn down the bass and up the volume. I have a high pass filter on my HU tho idk if you do... but thats what I do. Hope that helps.
My stuff
'06 Scion xA:
-Alpine iDa-x100
-Alpine KTP-445 Power Pack
-Polk Audio db6501 (front components)
-Polk Audio db651 (back coaxials)
-2 RE Audio SEX12D4s
-Cadence F1200-1D
- Custom box tuned to 33Hz
- Kinetik HC1400
- 50 ft2 of Audio Technix sound deadner
- Big 3
My photography page
a good max is like 3/4 of the total. (or at least thats what i use on my pioneer)
i notice that a couple clicks after that amount and i start to hear that nasty ass clippage.
gl bro
Rowan University Electrical Engineering
LINK TO MY BUILDDDDD
Current Setup in my 00' Hyundai Accent:
Pioneer DEH-P6900UB
RE.6.5C AUDIO 500w 6.5" COMPONENT CAR SPEAKERS
Eclipse SE 6500 (6.5 coax in rear deck)
two Kicker C124's in a t-line tuned to 28.6Hz
Kenwood KAC-7204
US amps 1600.4 V2
Upcoming Build this summer:
T-Line enclosure for two C124's tuned to 28ish hz O_O
amp my speakers with a US amps 1600.4.
Second Skin Should be fun ^_^
i dont mean to be all know it all.. but i dont think you cant hear cliping.. i think you mean distortion :drinks:
This guy sounds like he knows what he's talkin about (not saying this in a mean way) :drinks: :
[[[you can always hear clipping. It wil sound like a harsh "clack"
um, that's not clipping at all. What you're describing is "bottoming out"...when the sub's voice coil hits the back plate due to over-excursion.
Besides, subs dont clip...amps do. Clipping is a term that is used to describe the signal that the amp is producing. A normal signal is a sine wave, but a clipped signal becomes square. This square wave sends more heat to the sub and causes the sub's cone to not move as much as it should; hence, losing its ability to dissipate the extra heat. This can cause the sub's VC to fry.
The sound the subwoofer makes when an amp sends a clipped signal is generally just a distorted sound. You know how a certain note should sound, but when clipped, it sounds "off" or distorted. Many people refer to this sound in subwoofers as being similar to that of a "wet fart".]]]
My stuff
'06 Scion xA:
-Alpine iDa-x100
-Cadence F1200-1D
- Kinetik HC1400
- Big 3
My photography page
well put.. well this is what the form are for.. to learn something :good:
thats not the correct way btw, GL with fried equipment/shitty sound
  • Who's Online   1 Member, 0 Anonymous, 2109 Guests (See full list)
