checking coil with dmm
bassHZ
set my dmm to ohms and put it on my single voice coil 4ohm subwoofer and it bounced around around 3.4 and 4.something but mainly over 4.something is this a good thing what should a subwoofer coil check out at on the dmm and is it the same for number for like mids and highs and tweeters ??
sounds about right. remeber everytime the cone moves even a the a little it changes the impedence a little
R.I.P '01 blazer you treated my ears well until your transmission blew up.
New Project
[top secret]
149.0 db on music driver window open; so close
I feel some boners are fueled by viagra and not true intimacy!......if you know what i mean....
I swear... sometimes I wish I was retarded so I could just agree with everyone x.
ok is it the higher the number the better the woofer is or the lower the better cuz i checked other woofers and one metered at .08 the other higher than 1.0
I had the same question I need my subs to be at 1 ohm and the dmm is reading 1.2-1.4 this is with the subs in the box and im taking a reading off the speaker wire that goes to the amp but is not hooked up.
oo same here thats what i did the other subs i checked were 4ohm single and they metered lower like at 1.0
take your dmm set it to ohms and touch the leads together I'm willing to bet thats where the additional comes in at. Being that little over is not bad. if it was a 4 ohm coil reading like 16 or something it would be .
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
  • Who's Online   0 Members, 0 Anonymous, 2615 Guests (See full list)
