Alright so i traded my Kicker ZX1000.1's to a guy from caco for his memphis mcd-2500.1 it just showed up i plug the have 14volts at the temrinals but nothings making noise any ideas ?
Is it turning on?
Is it in protect?
Remote voltage?
Are the RCAs getting signal?
Are the RCAs in the input?
Did you check the speaker leads with a 9V?
Check that first, then you can start to worry about the amp.
EDIT: If there's a protect light, then check the ohm load. Those amps don't like anything below 1ohm without modding.
Edited by Neo_frog
Need an install? Hit me up.
[email protected]
Well the Green light one turn on but im also wondering if my rem wire isnt grounded out because it isnt showing a Voltage and no i dont have an output from speaker terminals
take a wire and jump from the + battery terminal on the amp to the REM turn on wire...and see if it comes on? but if the amp is already on then your remote is working..
DCAUDIO
BALLS DEEP
¿ǝɯɐƃ ǝɥʇ
hahaha nice
*** SuperSeller Status Verified *** ( http://www.stevemeadedesigns.com/board/topic/25829-super-sellers-buyers/ )
"kevosinn's" astro van
8 custom Sundown Zv4 18's
4 Sundown scv 6000's
CNF Distribution CNC parts
Skyhigh wire
some batteries
SMD Meters and tools used on the install
http://www.stevemeadedesigns.com/board/topic/172877-kevosinns-vanwest-coast-skyhigh-car-audio-vehicle/
16,000 watt walled silverado build.
http://www.stevemeadedesigns.com/board/topic/161965-walled-silverado-4-hdc4-15s-4-crescendo-3500s-and-much-more/
8,000 watt 1999 Subaru legacy outback. Build log here: http://www.stevemead...ru/page__st__60
TEAM CNF Distribution
