I don't plan to build one but I'm just curious. But are tunnels, like Tommy Mckinnie's, DJ's, Mr. P's all considered 4th order BP's in a way? And one's like BITLD's tunnel a 6th order? Also why does it seem like these always just murder the lows, never seen a tunnel that just didnt destroy the lows. Sorry but this has been on my mind lately.
because bandpass enclosures are much like a horn, and a horn has high efficiency due to active air movement at the mouth.. more air that is "active" the louder your system.. tunnel bandpass enclosures are even more like horns than normal bandpass, and technically the cab area is acting as a helmholtz resonator..
Hammerdown... 1%
i love learning new shit
2 Fi BTL N2 18s Fully LoadedSundown Audio NS-1Kenwood 845 HU Clarion EQ4 Juicebox 3100sKnu Wire"Big 3"Mechman 270a156.3dBTeam GG.
That is some really good information.
^it was
its just a big sealed box, dont overthink it :peepwall:
yeah basically, but it just has this big air-hammer trick up its sleeve ;)
Hammerdown... 1%
oversized sealed or spec sized?
1998 Monte Carlo Z34
Stock HU but have replacement
Stock Highs
Stock Electrical
BTL 18 sitting naked
AP1500D
The key for maximum efficiency of that effect would be the size of the tunnel. Based on the subs/power/roll off would determine the appropriate mass of air inside the tunnel and create it.
The problem is testing. The design takes so much effort that nobody (that I know of) takes the time to build it over and over to derive any tunnel equations since they would include some kind of factor that uses the cab space as a variable. I for one would love to see it done though.
Edited by Neo_frog
Need an install? Hit me up.
[email protected]
I think all we need to do is make the tunnel a bit longer and taper the exit, like a horn throat ;)
Hammerdown... 1%
  • Who's Online   0 Members, 0 Anonymous, 1035 Guests (See full list)
