magillaru Posted April 24, 2010 Report Share Posted April 24, 2010 I am trying to figure out if I can fit 2 DC Audio level 5 15's in my 2004 Honda Accord. I currently have 2 subs in their now, each with their own port (which leaves maybe a little extra room, but not much), which measures: 36" X 25.5" X 17" which would then be converted to: 3' X 2.17' X 1.42' = 9.2 cubic feet Is this right? Does this mean that I have 9.2 cubic feet to work with? Please tell me if my calculations are correct. Thanks! Singer Alternators Team Asshole #anothershittysingerbuild Link to comment Share on other sites More sharing options...
Neo_frog Posted April 24, 2010 Report Share Posted April 24, 2010 If those are exterior dimensions, then no, you will have less space. But you don't need to meet size requirements of the box. You can trade off the efficiency with more power. If the box is single thick, then the max measurements you have would be 7.42cu. That's fine for two 15s. Need an install? Hit me up.[email protected]Got car audio questions? Check here first!Everything you need to know. =]http://www.stevemeadedesigns.com/board/topic/83029-everything-you-need-to-know/ Link to comment Share on other sites More sharing options...
Neo_frog Posted April 24, 2010 Report Share Posted April 24, 2010 Expect to run them on a lot of power since the port will eat up more space. Need an install? Hit me up.[email protected]Got car audio questions? Check here first!Everything you need to know. =]http://www.stevemeadedesigns.com/board/topic/83029-everything-you-need-to-know/ Link to comment Share on other sites More sharing options...
magillaru Posted April 24, 2010 Author Report Share Posted April 24, 2010 If those are exterior dimensions, then no, you will have less space. But you don't need to meet size requirements of the box. You can trade off the efficiency with more power. If the box is single thick, then the max measurements you have would be 7.42cu. That's fine for two 15s. Yes, those are the external dimensions. Nice! Thanks! Singer Alternators Team Asshole #anothershittysingerbuild Link to comment Share on other sites More sharing options...
magillaru Posted April 24, 2010 Author Report Share Posted April 24, 2010 Expect to run them on a lot of power since the port will eat up more space. A lot of power....of course Singer Alternators Team Asshole #anothershittysingerbuild Link to comment Share on other sites More sharing options...
magillaru Posted April 24, 2010 Author Report Share Posted April 24, 2010 Expect to run them on a lot of power since the port will eat up more space. One port then? Or, can I have a split box, each sub with their own port (like I do now)? Singer Alternators Team Asshole #anothershittysingerbuild Link to comment Share on other sites More sharing options...
herbykw Posted April 24, 2010 Report Share Posted April 24, 2010 This site should help with the design. http://www.the12volt.com/caraudio/boxcalcs.asp X2 Should be 7.42cubes before sub and port displacement I run 2 15" XLs and i use one port, i like it. 06 300C 5.7 Hemi K&N CAI JVC KW-AVX640 6.1" DVD DC Audio 3.5k 6 DC Audio 8"s 6 cubes 8" aero port at 32hrtz http://www.stevemeadedesigns.com/board/topic/183798-chrysler-300c-8-build/?p=2731834#entry2731834 Link to comment Share on other sites More sharing options...
magillaru Posted April 24, 2010 Author Report Share Posted April 24, 2010 This site should help with the design. http://www.the12volt.com/caraudio/boxcalcs.asp X2 Should be 7.42cubes before sub and port displacement I run 2 15" XLs and i use one port, i like it. Nice website. Thanks! Singer Alternators Team Asshole #anothershittysingerbuild Link to comment Share on other sites More sharing options...
kirill007 Posted April 24, 2010 Report Share Posted April 24, 2010 I wouldn't do it. Do 2 12's, would sound better and can be as loud.(because it would be in it's optimal enclosure) And it's easier to fit the box into the trunk. Thinking is the root of all problems... You ALWAYS get what you pay for. Link to comment Share on other sites More sharing options...
