II was given a brandnew SSL Equalizer and i hooked it up and it sounded great lastnight after i adjusted everything. well thismorning i went to go and listen to my radio and the complete rightside of my car has like no highs but the mids play? did i blow the equalizer since its a cheap one because i have a kenwood excleon KVT819 with the 7 volt preouts ....mayb i fried the eq?
Edited by tumminellon
TermLab 148.9 @ 39hz BURP
148.8 on music
Try to bypass the EQ to make sure its the source of the problem and not a speaker or other problem.
but its only the right side of the car and i have two amps one for the front and one for the rear and both arent working?
148.8 on music
sounds like a good reason to try and bypass the EQ
if it is the eq that is the problem im goin to buy the clarion EQS746 and it is rated for max 4volt inputs but my radio has 7 volt preouts.... will it work??
148.8 on music
you hooked up a SSL eq with an Excelon deck? why insult an excelon like that?
Just to see if it made a diffrence and it did but i got my clarion eq on the way :)
F*** Cheapies
148.8 on music
