multiple battery question
will there be any noticeable difference if I run both the + and - from the front battery to the rear batt compared to running just the + and do the - to proper grounding spot in the trunk?
sorry if this is a repost search doesn't work well on my ipod for some reason
You will not really notice a difference.
You can cause engine noise by not having the batt grounded properly though.
Ed Lester
ShowtimeSPL Host
Showtime Electronics Video Marketing
My old Build Log
http://www.stevemead...08/#entry511451
http://www.youtube.com/showtimespl
5 time dB Drag Finalist
Last ride 2007 HHR, current dB 153.5 and bass race 149.4 dB. 153.0 dB on music
New Ride, 2008 HHR SS. Build under way.
Loudest score ever = 171dB
2009 dB Drag Racing, North American Points Champion
alright thanks. just wasnt sure if I needed to get more wire when my 2nd batt comes in or if I should be fine with a solid ground in the trunk
i have nver had a problem
with grounding the second batt in the trunk if you were to run alot of power say over 2k doing a run of 0 for your ground would be a bad idea
04 dodge dakota ext cab 4x4
excessive amperage 300 amp alt with MONSTER stud =)sundown z v3 15 in a 4th order on aq2200sundown 100.4 2 way active...2 Prv audio 6mb200 & 2 re XXX tweetersdeka intimidatorkenwood x396big 3 1/0 knu wire back to deka intimidator
  • Who's Online   0 Members, 0 Anonymous, 525 Guests (See full list)
