What Volume Headunits Clip At
I found a topic on facebook from sound connection inc about decks he tested and here are his results for those who have these decks and were wondering.
ll Kenwood Excelon video head units
Volume 35, all the way up at 1k hertz they have 4.3 volts of pure unclipped output on the front and rear channels.
Volume 35, all the way up at 40 hertz with the sub volume on +2 they have 5.61 volts of pure unclipped output.
These decks are amazing!
Full volume and absolutely no distortion. Please keep in mind these numbers are only RCA outputs and dose not mean your amplifier will be able to handle this much output before it distorts.
Excelon single din head units
3.75 volts at volume 35 1K Front and Rear unclipped
4.01 volts at volume 35 40hz Sub volume +1 unclipped
All filters, eq's, dsp, ect were shut off for testing.
Kenwood regular line single din head units
2.12 volts volume 32 1k front and rear ch unclipped
2.27 volts volume 32 40hz sub vol +1 unclipped
what one would a kenwood xxv-01d fall under it is a single din
  • 5 months later...
So I just got a pioneer avh-p4400bh and I was wondering if anyone has had a chance to dd-1 it yet?
2007 M/T Honda Civic Coupe EX
(4) Sundown Audio X-8's
(2) Ampere Audio 3800.1's
(3) Stinger SPV-44 Batteries
(1) Mechman 240
3:1 Ratio 4th order sealed from the trunk
TEAM NWSPL
Best termlab scores to date in Honda trunk:
151.7db legal (official) IASCA trunk 3 class
Best termlab scores to date in my walled Subie:
152.9db legal (unofficial) IASCA advanced 2 class
155db outlaw
Pioneer DEH 7400 hd clips at 60/62 with flat deck settings and all loudness and bass boosters off
My old YouTube channel : http://www.youtube.com/user/SwordLords1234?feature=mhee
My old build log : http://www.stevemeadedesigns.com/board/topic/161872-96-accord-b2-sundown-sky-high-dc-power-re-re-build-for-heatwave/page-37
My New Build - http://www.stevemeadedesigns.com/board/topic/207041-2016-mazda-6-sql-build/
2016 Mazda 6 Touring
JL Fix 86 - OEM signal correction
B2 prototype DSP 6to8
B2 Ref63 - 3 way active set
2 B2 Class H quattro's
1 B2 Zero.5R @.5
2 B2 HNv3 12 d2
B2 SLIP40 - Lithium in the trunk
Northstar Group 35 under the hood
100ft 2/0 welding cable
30ft 4ga welding cable
20ft 8ga welding cable
All stinger OFC speaker wire
Soundrive custom RCA's
Tons of attention to detail.... Can it be perfect?
  • 3 weeks later...
I'm new to this stuff, but wouldn't it be better to set gains with the eq settings where you like them instead of flat. Goes for measuring clipping point as well. I know I don't like the sound of mine with everything turned off and flat. Just wondering if it would be better for me to set gains and measure clipping with the eq and settings how I like them. Is that ok to do. Or is that completely wrong? Does everyone have there eq set to flat, loundness off all the time, all settings off? I don't like to listen to music with everything flat. Any response appreciated, trying to learn. I have a pioneer 7200hd by the way.
  • 3 weeks later...
Kenwood Excelon KDC-X994
35/35 unclipped at the preouts both at 1khz and 40hz with all settings flat
Will update with what the internal amplifier clips at.
Since everyone sets their EQ/Bass/Treble differently, it's best just to state it with everything flat, all processing off. If you are setting your own gains with a DD1/oscope I'd definitely set it the way you listen to it.
2007 Pacifica
  • Who's Online   1 Member, 0 Anonymous, 963 Guests (See full list)
