Alpine amp is cooking hot..?
just make sure the amp is flat and not mounted up and down...Might help with the cooling a little bit
It is, it's ventilated fine as well.
2003 Ford Crown Victoria P71
2 12" Kicker CVX's
Audiopipe AP15001d
Stinger SR80 Isolator with DieHard 1200CCA battery
Streetwires 0awg
Secondary - 1998 Ford Expedition XLT
all the MRP series ive seen have been just warm to the touch, ive even seen them below ohm load doing fine at ~1ohm
I have the MRP-F600 and havent had any heat issues with it, id check ur ground make sure its got a good clean connection.
06 Impala SS
Kenwood Excelon DDX593
Ampere Audio 150.4
Ampere Audio 5K
1 XS D4700 (front)
Mechman 320a Alt. w/ Big 3
Lots of Second Skin Damplifier
Under Construction for 2017
mounting it flat will cause the amp to get hot. if you mount it on the back of a seat or on your box it will run much cooler. i have an alpine mrp-f300 and that seems to be the case for me.
(Headunit) Pioneer DEH-P3100UB
(Speakers) Phoenix Gold RSd 65cs
(4 Channel) Alpine MRP-F300
(Subs) 2 15" Audioque SDC2.5
(Box) 7.27 cubic feet tuned to 31 Hz
(Mono Amplifier) Elemental Designs Nine.1
(Wiring) 1/0 Knukonceptz KLMX
(Batteries) 2 C&D Tech 75 a/h
problem solved.. sub wires were fucking up the ohms.. but i have another question...
The box has 4 total wires coming out of it (1 pos and 1 neg for each sub)
I only get the amp to stop over heating if i only connect 1 sub to it since it only 1 pos and 1 neg terminal on it. How do i wire both subs together in order to connect them to the amp? wired 2 ohms by the way.
2 12" Kicker CVX's
Audiopipe AP15001d
Streetwires 0awg
jesus fucking christ...people figure out the ohm loads of your subs before you just toss them on an amp.
after this whole thread come to find out the problem is you had no idea what you were doing when you wired it or whomever wired it....ALWAYS check your wiring
I'm wondering because I have wired them together like that into a different mono block amp with single terminals before with no problems.. Instead of flaming how about you just help? Honest mistake, sorry it ruined your day.
2 12" Kicker CVX's
Audiopipe AP15001d
Streetwires 0awg
http://www.rockfordfosgate.com/rftech/woofer_wizard.asp
My RE MT 18" wall build Former build, farewell beloved wall.In progress, Toyota Starlet build
This forum has a massive boner for ridiculous electrical upgrades.
  • Who's Online   0 Members, 0 Anonymous, 2018 Guests (See full list)
