psx2p Posted May 3, 2010 Report Posted May 3, 2010 is it wise to have multiple components hooked up to a distro block which is then grounded? if not whats your preferred grounding method? 01 GMC Sonoma 4x4 RF T1500.1bd DC LVL 4 12"
AssKicker Posted May 3, 2010 Report Posted May 3, 2010 You want to ground the exact same as your power runs are. For example: 2 runs of power, 2 runs of ground or If you power is through a distro as well, match that exact thing and ground. I prefer this method.
jizazz12 Posted May 3, 2010 Report Posted May 3, 2010 nothing wrong with using a distro block, i have done it in the past and never had issues. 2007 Chevy Impala LS 1 Crescendo 3KWP 1Crescendo C1000/4 2 DC lvl 4 15's with lvl5 dual .7 coils 1Audio Control Matrix 1 Pioneer P880PRS 1 300 amp Iraggi alt All power runs done with Knu flex 0/1 guage 1 optima yellow top under the hood 1 XS 5100 and two Deka's in the trunk 4 Crescendo MP-8 mid bass drivers 2 DB Drive p5 5 D Pro Audio tweeters
psx2p Posted May 3, 2010 Author Report Posted May 3, 2010 ok thanks im waiting on the local shop to get some 1awg for some other stuff, should i use some to ground that distro block im using as ground? i have 4awg running to the ground block then 4awg from the block to the chasis 01 GMC Sonoma 4x4 RF T1500.1bd DC LVL 4 12"
jizazz12 Posted May 3, 2010 Report Posted May 3, 2010 how much power are you running? if it's 5-800 watts 4 gauge would be OK but if your running more than that you should have 0/1 gauge on it. 2007 Chevy Impala LS 1 Crescendo 3KWP 1Crescendo C1000/4 2 DC lvl 4 15's with lvl5 dual .7 coils 1Audio Control Matrix 1 Pioneer P880PRS 1 300 amp Iraggi alt All power runs done with Knu flex 0/1 guage 1 optima yellow top under the hood 1 XS 5100 and two Deka's in the trunk 4 Crescendo MP-8 mid bass drivers 2 DB Drive p5 5 D Pro Audio tweeters
CaptainzPlanetz Posted May 3, 2010 Report Posted May 3, 2010 I would trust quality 4 gauge up to around 1500rms, given it is less than around 17-18ft. long. ¿ǝɯɐƃ ǝɥʇ Trolls never learn............ All BS aside, If I see one more comment in here that is NOT about the pre-sale, I will start the vacations. And that includes the trolls feeding the trolls. YOU THE ONE THAT SOUND LIKE A OGER AND HUMPBACK/TROLLS? Add "SMDLIFER" on Xbox LIVE to play with other SMD members.
