help on charging a batt in car.
ohkay so i have a question on how to charge a batt. its in the car now and i bought a cheap schumacher sc-1000a for like 40 at autozone. do i have to take it out of the car or can i just charge it in the car and if so do i have to disconnect the ground for the chassi and my wires going to the amps?
i charge my batteries at times while it's hooked up in my truck, i disconnect nothing, just connect the + and - clamps from the charger and that's it. now i use to do that before i got the MLA ........... with my batteries seeing 15.3/4 every day i really don't need to charge them.
2-DC 15XLM2 D.7s
1-DC 5K amp
Audiocontrol 3.1.
you can charge it in the car... i jus wouldnt recommened starting it while on the charger.. unless you have a 50 amp charging start option on the charger... either way... no problem charging it while hooked up...
My first truck... My first Real build...
*Update 8/9/10 DC Power 270xp Alt is In!!!*
1997 Toyota T-100 DC Level 5 18" in a T-line
Everybody wants their system to be....
1. Cheap
2. Reliable
3. Loud
...you can only pick two.
micahmye hertz pack
So I hook the Charger an then crank the car and let it charge or crank it first and then plug it up? And why does cranking it or leaving it turned off matter??
if its got the little caps on top pop them off when you charge the battery put (+)on (+) and (-) on (-) when on a charger its so easy a caveman can do it
BUILDLOG
http://www.stevemeadedesigns.com/board/ind...showtopic=61862
"98crewcab"Never a POS....just always "a work in progress" lol that's how we roll bitches!!!
Your a lowlife kid. I bet your mother wants to kill herself for not swallowing your ass.
I know but someone told Meh that's the grounded part of the bat that goes to the chassiust be disconnected and I just wanted to make sure if it was true or not. So car on or off??
dude, you are over complicated the easiest thing. The answer has been said a few times already. Car off BTW
I love my staffie :good:
So anti FACEBOOK it isn't even funny
  • Who's Online   0 Members, 0 Anonymous, 1399 Guests (See full list)
