amp says 1/0 but use 4 gauge?
chapo123
how about if i use 0 gauge from the amp to my back batt then do a run of 4 gauge to the front??
meh
get some two gauge if you cant get 0
if you cant get either then dont worry about. just be wise about how you play
-Matt
2005 Dodge Magnum RT
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
Audio Legion 3500.1D
2 RE MT 18s
360 ah LiFePO4 Battery
SHCA 2/0
155.2 @ 29 hz
Kicker CVR 15's build
DD 3512e build
Mini T-Line Build
(6) 8s Build
Nightshade 15s Wall Build
Magnum AB XFL 12s Build
Newest Magnum Build
because i already used up the 20ft of 0 gauge i had in the other car for the btl. this is gonna be for 2 12 type r's. and the car has a stock 140 amp alt i think. not sure if that affects this question much
Steve I don't know why but everytime I see your new paint I want a Dr. Pepper...... is this normal?
heres an analogy for you. running a high power stereo without a fuse is like having unprotected sex with that hot chick at the bar with the sketchy sexual history. Sure you may be fine and nothing happens but that one time something does happen you're fucked.
i dont want woofer broke like bass sound clip clip and voice coil overheat
2 sa12s, saz1500 build log http://www.stevemeadedesigns.com/board/topic/91183-chapo123s-sundown-build-log/page__gopid__1250604entry1250604
I'm assuming the IDK in your name stands for I Don't Know. Because man, you sure as shit don't know what you're talking about.
more current will flow to the amp from the battery, but the alt wont be able to charge the battery as fast as the amp is draining it. plus you will more than likely burn the fuck out of the 4 gauge. use 0 gauge. you wont regret it later on.
Just get 0..... Not a tough decision
*** SuperSeller Status Verified *** ( http://www.stevemeadedesigns.com/board/topic/25829-super-sellers-buyers/ )
"kevosinn's" astro van
8 custom Sundown Zv4 18's
4 Sundown scv 6000's
CNF Distribution CNC parts
Skyhigh wire
some batteries
SMD Meters and tools used on the install
http://www.stevemeadedesigns.com/board/topic/172877-kevosinns-vanwest-coast-skyhigh-car-audio-vehicle/
16,000 watt walled silverado build.
http://www.stevemeadedesigns.com/board/topic/161965-walled-silverado-4-hdc4-15s-4-crescendo-3500s-and-much-more/
8,000 watt 1999 Subaru legacy outback. Build log here: http://www.stevemead...ru/page__st__60
TEAM CNF Distribution
i cant believe nobody has asked this yet:
how long is the run?
if the run is from the front battery to the amp, then you need to use 1/0
if the run is within 3 feet of the battery, you should still use 1/0 but could probably get away with 4 (if you had some laying around already)
8 DC Level 4 M2 15s2 DC Audio 5ks26^2 clamshell tuned to 30hz9 Kinetik 1400sMechman externally reg'd 340 S seriesin a 99 Jeep Cherokee :DClick to see J00bles' Youtube Channel
i have some left over 1/0 that i could use. its the thing is i already did the run and it would be a bitch to rewire it lol
15-18ft but yeah i guess imma just leave it like that but use 1/0 for the amp. thanks guys
  • Who's Online   0 Members, 0 Anonymous, 243 Guests (See full list)
