Hi, I'm building a box for two 12" kicker l5's. For aesthetic reasons, we are wondering if a single 4" diameter port can be put, and if it is possible to have that in the back of the box rather than the front like you always see.
You need much more port than that.
I'm not too familiar with L5's but I'm sure someone else can give you box ideas.
As for port out the back...I guess you could do it. Not sure how you mean to do it but shouldn't be an issue.
Actually what you could do if you had like a fold-down armrest in your backseat or something is make a slot port that goes through that hole.
Too many projects, too little time...
For a 15" i would at least 3 c/f and 1 6" port, yes the port size depends on the box size...
For 2 12´s and 4 c/f i would no less than 3 4" , even that i think it could have some port noise depending on the power you have.
This is starting to confuse me, because I thought that it was about square inches of the port for how much cubic feet I have. And based on that I need Roughly 64 square inches for 30hz in a 4c/f box. So, by having a 4" tube that is 4.5" long, I'm at about 56 square inches, which gives me 33.8 hz
and i'm at 1200 watts power rms btw
Edited by jarod027
That rule is mostly for slot ports, aeroport are more efficient, a round port needs about 9-13 SQ of port per cubic feet, said that, that´s why i would use minimun 3 4" ports, besides that, where do you get 56 SQ of port with a single 4" tube?????
pi x ®2
3.1416 x (2)2
3.1416 x 4 = 12.57 square inches!!
3 4" ports would be 37 square inches
Simple basic maths...
Actually my friend, it does not. . .but it is a nice approximation for those that cannot figure out how much port area they really need. . .
Current system:
1997 Blazer - (4) Customer Fi NEO subs with (8) American Bass Elite 2800.1s
Previous systems:
2000 Suburban - (4) BTL 15's and (4) IA 40.1's = 157.7 dB at 37 Hz.
1992 Astro Van - (6) BTL 15's and (6) IA 40.1's = 159.7 dB at 43 Hz.
