Stereo 2 ohms (how do I.......)
I basically have four, 4 ohm speakers. How would I wire them to get the most out of the amp?
If its possible im going for the 500 x 2 at 2 ohm.
4ohm speakers need to be run at 4 ohm( correct me if im wrong please) also what type of speakers, model number etc
Legal TL scores145.6 on the dash sealed up in the low 40hz area with the port out145.5 on the dash sealed up @30hz with the port inless then 1k clamped on a 3.5k!
Why would you EVER WANT flex?
huh?...flex is what can make the lows lower and more air being pushed correct?
me_zps0fb5a5b4.jpgMy FeedbackJeep-BuildlogPT LOSER buildlog
it iz a 4channel you nooooobbbbb :D, read the OP
HA HA HA you got me man. :rofl::good:
Isobaric - Refers to the practice of coupling two drivers together to make them act as one.
"Giving up doesn't always mean you are weak; sometimes it means that you are strong enough to let go."
Insanity: doing the same thing over and over again and expecting different results.
The Destruction of a person builds character.
I want to explain this to you but I type really slow, so let me say you probably won't like the out come if you put all 4 speakers on a 2 channel amp since you won't beable to balance your sound.
I recommend a 4 channel amp for what you would like to do and thats 85 watts to each speaker man.
Thanks for the recommendation! I dont care so much about Left to Right (balance), I would like to be able to control fade though.
If people are commenting, sorry I type slow also.
No, 4 ohm speakers can run at 2ohms since the speaker isn't effected. Only the amp putting out the power. Wire every 2 speakers parallel to a channel. Example...
Speaker1 + to amp +
Spekaer 2+ to same amp +
Speaker1 - to amp -
Speaker2 - to same amp -
This will put a 2ohm load on each channel but the speakers are still 4 ohm speakers.
2013 F150 Crew Cab
Old Build Log
Feedback
2013 F150
Not sure what you mean by running a speaker at a certain ohm. A 4 ohm speaker will always be a 4 ohm speaker, you can't "run" it at anything else.
F150:
Stock :(
2019 Harley Road Glide:
Processor: DSR1
Lid (Rear) 6x9s -  TMS69
Can we leave it at; your better off not doing what you want to do and you would blow the speakers if you do do it.
Wire each speaker to a single channel and be happy with it or else you might get headaches.
iso got owned xD lol
if u want a 2 ohm load just wire all the (+) and (-) of TWO speaker
http://www.the12volt.com/caraudio/woofer_configurations.asp?Q=2&I=41#results
________________________________________________________________________
deepsilencer, on 22 Aug 2011 - 17:32, said:
splzx3, on 22 Aug 2011 - 17:27, said:
i had my fun on one of his videos...till he blocked me then i got my mother into it lol after her he closed the comments xD
WTF, I never thought I'd have a conversation about cross dressers and trans-genders on a car audio forum.
There's nothing wrong with wiring a pair of 4 ohm speakers to 2 ohms, but in this case it simply isn't necessary.
This is just another one of those "I don't want to waste any of my amp's power" type of threads. Newbies post this type of question at ca.com almost every day...
You can't fix stupid
  • Who's Online   0 Members, 0 Anonymous, 665 Guests (See full list)
