Freshman6969 Posted May 10, 2010 Report Share Posted May 10, 2010 I basically have four, 4 ohm speakers. How would I wire them to get the most out of the amp? If its possible im going for the 500 x 2 at 2 ohm. 4ohm speakers need to be run at 4 ohm( correct me if im wrong please) also what type of speakers, model number etc Quote Legal TL scores145.6 on the dash sealed up in the low 40hz area with the port out145.5 on the dash sealed up @30hz with the port inless then 1k clamped on a 3.5k! Why would you EVER WANT flex?huh?...flex is what can make the lows lower and more air being pushed correct? My FeedbackJeep-BuildlogPT LOSER buildlog Link to comment Share on other sites More sharing options...
ISO Posted May 10, 2010 Report Share Posted May 10, 2010 it iz a 4channel you nooooobbbbb , read the OP HA HA HA you got me man. Quote Isobaric - Refers to the practice of coupling two drivers together to make them act as one. "Giving up doesn't always mean you are weak; sometimes it means that you are strong enough to let go." Insanity: doing the same thing over and over again and expecting different results. The Destruction of a person builds character. Link to comment Share on other sites More sharing options...
typicaljawaiian Posted May 10, 2010 Author Report Share Posted May 10, 2010 I want to explain this to you but I type really slow, so let me say you probably won't like the out come if you put all 4 speakers on a 2 channel amp since you won't beable to balance your sound. I recommend a 4 channel amp for what you would like to do and thats 85 watts to each speaker man. Thanks for the recommendation! I dont care so much about Left to Right (balance), I would like to be able to control fade though. If people are commenting, sorry I type slow also. Quote Link to comment Share on other sites More sharing options...
MrSkippyJ Posted May 10, 2010 Report Share Posted May 10, 2010 Where would I be as far as power? 105 watt per speaker? Yes, and that would be the correct way to do it. Quote F150: Stock 2019 Harley Road Glide: Amp: TM400Xad - 4 channel 400 watt Processor: DSR1 Fairing (Front) 6.5s -MMats PA601cx Lid (Rear) 6x9s - TMS69 Link to comment Share on other sites More sharing options...
Robert8252 Posted May 10, 2010 Report Share Posted May 10, 2010 No, 4 ohm speakers can run at 2ohms since the speaker isn't effected. Only the amp putting out the power. Wire every 2 speakers parallel to a channel. Example... Speaker1 + to amp + Spekaer 2+ to same amp + Speaker1 - to amp - Speaker2 - to same amp - This will put a 2ohm load on each channel but the speakers are still 4 ohm speakers. Quote 2013 F150 Crew Cab Old Build Log Feedback 2013 F150 Equipment - Some Awesome Stereo Sound Making Stuff Link to comment Share on other sites More sharing options...
typicaljawaiian Posted May 10, 2010 Author Report Share Posted May 10, 2010 Could I wire the two door speakers from single 4 ohm down to 2 ohm, and same for the rear? That way giving me two channels @ 2 ohm. Again sorry I type slow. Quote Link to comment Share on other sites More sharing options...
MrSkippyJ Posted May 10, 2010 Report Share Posted May 10, 2010 4ohm speakers need to be run at 4 ohm( correct me if im wrong please) also what type of speakers, model number etc Not sure what you mean by running a speaker at a certain ohm. A 4 ohm speaker will always be a 4 ohm speaker, you can't "run" it at anything else. Quote F150: Stock 2019 Harley Road Glide: Amp: TM400Xad - 4 channel 400 watt Processor: DSR1 Fairing (Front) 6.5s -MMats PA601cx Lid (Rear) 6x9s - TMS69 Link to comment Share on other sites More sharing options...
ISO Posted May 10, 2010 Report Share Posted May 10, 2010 Can we leave it at; your better off not doing what you want to do and you would blow the speakers if you do do it. Wire each speaker to a single channel and be happy with it or else you might get headaches. Quote Isobaric - Refers to the practice of coupling two drivers together to make them act as one. "Giving up doesn't always mean you are weak; sometimes it means that you are strong enough to let go." Insanity: doing the same thing over and over again and expecting different results. The Destruction of a person builds character. Link to comment Share on other sites More sharing options...
splzx3 Posted May 10, 2010 Report Share Posted May 10, 2010 iso got owned xD lol if u want a 2 ohm load just wire all the (+) and (-) of TWO speaker http://www.the12volt.com/caraudio/woofer_configurations.asp?Q=2&I=41#results Quote ________________________________________________________________________ deepsilencer, on 22 Aug 2011 - 17:32, said: splzx3, on 22 Aug 2011 - 17:27, said: i had my fun on one of his videos...till he blocked me then i got my mother into it lol after her he closed the comments xD lol your mom is a G! WTF, I never thought I'd have a conversation about cross dressers and trans-genders on a car audio forum. Link to comment Share on other sites More sharing options...
chud Posted May 10, 2010 Report Share Posted May 10, 2010 4ohm speakers need to be run at 4 ohm( correct me if im wrong please) also what type of speakers, model number etc There's nothing wrong with wiring a pair of 4 ohm speakers to 2 ohms, but in this case it simply isn't necessary. This is just another one of those "I don't want to waste any of my amp's power" type of threads. Newbies post this type of question at ca.com almost every day... Quote You can't fix stupid Link to comment Share on other sites More sharing options...
