here is an idea i had to be cheap
psu's have two outputs that are +12v
and it is possible to get a decent amount of amperage from one fairly cheap
so... is there anything horribly wrong with hooking the 12v sources up to a car amp?
just thinking and couldnt think of a better place to ask than here
-Matt
2005 Dodge Magnum RT
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
Audio Legion 3500.1D
2 RE MT 18s
360 ah LiFePO4 Battery
SHCA 2/0
155.2 @ 29 hz
Kicker CVR 15's build
DD 3512e build
Mini T-Line Build
(6) 8s Build
Nightshade 15s Wall Build
Magnum AB XFL 12s Build
Newest Magnum Build
You can hook it up but can't turn it up too much depending on PSU and amplifier
Edited by Big Lo
Any good PSU will have the Amp rating of the Rail(s) on the side. A good PSU can put out ~30 Amps per rail so you might be able to CAREFULLY power a smaller amp. I would recommend a 12V car battery with a little charger on it, that how we do our test bench in my shop
lower tuning is just hard. I was surprised how loud 145 sounds at 35hz, and how quiet 145 sounds at 50hz.
-= 2005 Tahoe LT =-Head unit: Pioneer AVH-X5500BHSSource: iPad Mini in dash
Subs: 2 T1 12's
Sub Amp: T1500-1bdCPWire: Rockford Fosgate 1/0 awgSignal Cable: MonsterFronts:Stock Bose for now:)Rears: Stock Bose for now:)MIds/High amp: Stock Bose for now:)
2005 Tahoe Build Log: http://www.stevemeadedesigns.com/board/topic/172529-2005-tahoe-my-17th-vehicle/
2001 Monte Build Log: http://www.stevemeadedesigns.com/board/topic/160030-2001-monte-carlo-my-16th-car-lol/page-2#entry25309381997 Tahoe Build Log: http://www.stevemead...oe-6-15-rf-15s/2001 Impala Build Log: http://www.stevemead...katzkin-inside/SMDSig3-26-12.jpg
you can connect it that way, i did it for awhile to just play with speakers in my room. made a cardboard vented box for a $7 8" i bought lol. youll want to just connect all of the power wires and grounds to one amp though, so it can get all the power it needs. it depends on what PSU you buy, you could buy a 500 watt PSU that would produce around 50 amps of current. the voltage usually sticks around 11.50~ or so when playing music.
200a alt. by Excessive Amperage
hc800 under hood & 2 Deka 9a31 in rear
1/0awg + big 3
SAZ 3000D
HDC3 18" @ 2 ohm
I have a buddy that did it with psu's but there wasnt enough power to power a 200 watt amp with 3 linked together. So he wound up using like 97SSBlazer said and hooked up a 12v batt to a charger and did it that route.
if you use ALL the 12v leads in a PSU i dont see why you cant power a 300-400w amplifier. hell you can daisy chain PSU's by hooking them up to the amplifier (not twisting + and - together and shit, just all the yellow wires to the + on amp and same amount of black wires that are next to yellow wires to - on amp)
Just got to look at the amperage a PSU can provide on the +12 volt rails, add if it has multiple rails add up the values, and then look at the fuse rating on you amplifier and this will tell you if your PSU is good enough for the amp.
Take a look at this: http://www.lehigh.edu/~evb209/projects/jlsubs/jlsubs.html
I found that a long-ass time ago and by looking at it and like two more he has on his website I was able to hook something up in my house.
What I also do is put a pair of resistors in series through the 4 volt rail (red wire) to "stabilize" the 12 volt rail, I learned it through another website but I don't know if I got a link or not. Can't remember the ohm value on the resistors but I can check tomorrow if you want.
