ok in the future i will bag my ext 2001 dodge fullsize truck. and my bro-in-law told me that he heard that you can use the ac compressor to lift and lower the bags. dont need a tank just the solenoids and lines. and if this is true is it cheaper and better. or just retarded.
SONY XAV-701HD
RF power 400.4 RF power 1000bd
3 Sundown x8's d2
2004 f150 single cab
2 sets of components MB quart 6.5 onx (2 tweets 2 6.5 perdoor)
stock batt up fron
BIG 3
http://www.stevemead...-vid-pg-11-922/
http://www.youtube.c.../TheBigmescan74
you use an AC compressor for an EDC setup but you still need a tank for reserve. It is also an extra AC compressor not the one you use for your air conditioning in the truck.
2003 Ford F-150 Reg Cab layin body on 26's
2003 Tahoe 3/5 drop on 26's with a 408cid Supercharged engine.
2011 Camaro 2SS 2005 VW GTI Stage II ECU, CAI, 3" turbo back exhaust, FMIC, lowered 2" on some plastidipped 18's
2003 Hayabusa lowered, stretched, cams, nitrous and custom paint
yeah i knew about getting extra ac comp. but is there an advantage to doing this. and you do need a reserve tank.
SONY XAV-701HD
3 Sundown x8's d2
stock batt up fron
BIG 3
i still wish i lived in texas. there where alot more places to get this type of work done for pretty cheap. here in NC you are always hearing go to that shop 4 hrs away. no way man go to this shop 3 hrs away. but i may have to join a car club that has a few people that say they would help me all the way. i just need to know which way to go. baggin or hydro.
SONY XAV-701HD
3 Sundown x8's d2
stock batt up fron
BIG 3
bags for sure and you will still need a tank. The advantage of an EDC is that they fill way faster so you have more air to play with or you can have a smaller tank if you are short on room.
Edc ftw
2001 Bravada (2wd) Pewter on 24's
JVC KW-AV60BT
10 Alpine Type-S 6.5s
2 PSI/BTL 18's @ 32Hz
2 Rockford Fosgate T25001-bd's @ 1-ohm each
Rockford Fosgate T1000-4
Rockford Fosgate T400-4
Rockford 3Sixty.2
Yellow top up front, 2 9a31s in the back
LOTS of AT 1/0
Python 991
350 Amp Singer Alt
"Build Log"
My Facebook
My YouTube
i didnt see the video or read anything but...cool story
and the reason your being a cock tonight is?
you can't just use any air cond. compressor , look into finding a Sanden from an older model jeep cherokee years 81-90 , the jeep comanchee years 86-90 , 81-90 jeep wagoneer , 87-90 jeep wrangler . you want the Sanden 7 compressor , these things will pump out about 300 psi !!!! and yes , youy use a tank . you are basically replacing a 12 volt compressor with this engine driven compressor .
thanks for that info
SONY XAV-701HD
3 Sundown x8's d2
stock batt up fron
BIG 3
  • Who's Online   1 Member, 0 Anonymous, 1152 Guests (See full list)
