Anyone With A Fosgate Power Series Amp Here Please!
Guest dropthabeat.com
hey, that screen mesh in the middle of your amp, is the fan sucking or blowing out of there? i put tissue to mine and couldn't see it do anything. i wonder if they put just a chintzy little fan in there. :angry:
depends on the amp... the T20001bd has the fan right under that grill, the T3k and T4k have 2 fans one on the left and one on the right no where near the grill (not sure on the T1k but i think its like the 2k)
also the fan(s) arent always on or always on full speed... theres 3 or 4 speeds depending on the amp temp
J. Jsig_253411.jpgMy CardomainFINISHED COBALT SS/SC DUAL ALTERNATOR PICS icon_nuts.gif
theres no such thing as too expensive when it comes to upgrades like that, because imo if you are gonna spend to upgrade then do it correctly rather then be a cheap ass ricer
the t1001b fan is right under the center piece.
RF Punch 40x2RF Punch 100x2RF Punch 200x2RF Punch 200x2RF Punch 400x4JL Audio 10W7-3"but its only a 200 watt amp tho"
its pulling the air in and the heat sink is pulling the hot air out...it works as a cycle. generally the fan is NOT turned on unless temps start to raise.
i have heard there are ways to have it constantly tuend on but you gotta send it to the factory
NoFearX18 said:
thanks for all the replies guys, i've had my amp trip a few times on thermal so i was wondering. then again it's constantly over 110 degrees out here now so my trunk has to be hotter. i recently welded a frame for my amps to sit about 4 inches off the ground with an open bottom for more circulation. also have a 5" ball bearing fan blowing in cooler air from the cab into the trunk now so lets see how that works. with the size of the box, doesn't leave much air space in there.
