so this is kinda a double post from my topic a few days old but really its just a quick question and i figured id save ya'll the hassle of reading the other thread.
So im trying release the belt tensioner so i can remove my alt, and do the big three.
ive got the 1/4'' breaker bar in the tensioner slot, and when i push down, the belt moves, but isnt the tensioner suppossed to like have a on/off position if you will.
i push down and down some more and nothing happens, am i posed to remove the belt while pushing down, it seems kinda tight still, i thought you turn the tensioner to off, and the belt slips off if you will
heres the scematic from before
thanks
Setup:
2010 Hyundai Elantra
Factory Unit via 4 chan NVX LOC
Excessive Amperage "H/O" Alt
Xs D3400/ Xs XP3000
Big 3. 2 Runs of +, 2 Runs of -
DD M3b and 2 12" AQ HDC4s
tensioners are spring loaded
Turn it as hard as you can and simultaneously pull the belt off of one of the idlers, let up on the breaker bar and remove the belt
And what do you mean you have it in the slot? you put a socket on it, and turn that nut at the end of the tensioner arm and it rotates the whole thing
Edited by 95_1500
Put a ratchet into that square hole and push down, if you can't add some leverage and it'll work
2003 CHEVY TRAILBLAZER
AKA The Batmobile
Pioneer 6000UB
Sundown SAZ-3000D
2 Audio Q HDC3's
40' of 1/0 Gauge
2 Big Rear Batteries
A 38 HZ Box
KICK ASS!
yea the tensioner, has a a square hole for a socket to fit it as in the diagram above, pushing down rotates the whole thing as per the diagram should loosen the belt, im asking if the i have to simaltaneously push down and remove the belt or do i push down until the tesioner stops.
i was under the assumption that the tensioner will eventually unlock in a loosen position, where as to say that the belt will remain loose without pressure turning it and you are free to loosen the belt and when you're done simply turn it back to tighten the belt?
Setup:
Xs D3400/ Xs XP3000
You push down as far as you need to while simultaneously removing the belt. The tensioner will never stop giving tension. Just get out there and do it, don't ask questions lol. It's not that hard.. you'll figure it out.
1985 Chevy Silverado Black and Silver SBC 350/700r4
the tensioner is spring loaded get your back into it and pull off the belt at the same time and reverse when you want to put the belt back on
06 chrysler 300C Hemi
one mmatts dreadnaut 15 powered by a planet audio vx 2200d
fosgate p200 running planet audio 8" midbass drivers and super compression tweeters
stock battery and a stinger spv44
Irragi 300 amp alternator
big 3 1/0
http://www.stevemeadedesigns.com/board/topic/55075-system-in-my-300c/page__view__findpost__p__763656__fromsearch__1
im stupid, i got it
Setup:
Xs D3400/ Xs XP3000
im out of time and kinda gotta go to work so ill finish this up tom, but, the alt only has one wire coming from it, im positive it well the postive, its one of the those one wire charging alt..? its grounded dirctly to the black via a thick as mounting bar, im not going to run the wires today obvi, but just to make sure,
the single wire is my posi right?
i suppose i could hook it back up without the gay ass shroud for a sec and use the dmm to check?
off to work for now, but thanks for all that helped me through my stupidity.
P4Killer
Setup:
Xs D3400/ Xs XP3000
  • Who's Online   0 Members, 0 Anonymous, 4424 Guests (See full list)
