vexpro/sundown 07 caddy WALLED vids NE1
Pretty slick man... You do impressive work.
Now youve got me curious as to what 5/8 bolt got cut that could cause issues... ...
Either way... great work!
-Chris
03' Black Z71 Tahoe
3" Lift / 315/70/R17 Goodyear Duratracs
Eclipse AVN6620 Touchscreen Head Unit
Hifonics BRX3016 - 3krms @ 1ohm
2 RE Auido SX 18s - 14.5^3ft net @ 30hz w/ 200^2in. port
120hp Cummins 4bta Swap
why all the expanding foam?
R.I.P!
(Nov-29-2009)
92 explorer
current build
To be honest the truck is built like shit it is VERY thin the rear quarters was flexing like there was no tomorrow and sounded like shit so I took regular house fiberglass insulation and filled the depth of the entire gap and then foamed the Hell out of it and I must say it made the world of difference in the overall sound also
the lit up amp rack is just beautiful
-Matt
2005 Dodge Magnum RT
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
Audio Legion 3500.1D
2 RE MT 18s
360 ah LiFePO4 Battery
SHCA 2/0
155.2 @ 29 hz
Kicker CVR 15's build
DD 3512e build
Mini T-Line Build
(6) 8s Build
Nightshade 15s Wall Build
Magnum AB XFL 12s Build
Newest Magnum Build
  • Who's Online   1 Member, 0 Anonymous, 1744 Guests (See full list)
